hey having trubles with my rb25det s2
well when i first put engine in my car would drive good but there has always had a very little hisitation from round 5500 to 6500 but hardly noticable
has fmic, exhaust, only ever run 9psi
but then it started backfiring hard between 5-6.5g
i decided to wire up up an ignitor and wasted spark
has new vn coil and leads with 8 months old platniums
checked them and the white ceramic was cracked on one and you could c were it had been arc'n through so replaced with a spare irridium ( if anyone knows wot 45 dollar ones to put in)
know when it gets to round 4500 it just misses/pings, doesn't even rev past 5 easly
it seems to change behaviour(getting worse)
tried changing cas but no change
https://www.sau.com.au/forums/topic/273798-rb25det-power-troubles/
Hold on what. THIS IS BAD
You put 2nd hand plugs in it and VN coils? like commodore coils wasted spark ignition? why?
NGK bkr6es is copper replacement plug for these things.
PUT THE STANDARD IGNITION SYSTEM BACK ON!
the standard ignition system is fine... when working properly.
check timing
doulble check boost
don't drive car till it pings this will cost you another engine.
try turning CAS all the way clockwise to minimize ignition timing before you drive anywhere
get your Air fuel ratio checked asap any 4wd dyno place will do it to confirm fuel issue.
a chipped plug would confirm major detonation event has occured, unless it was damaged on installation or removal.
I'm not surprised you have power troubles with mixture of irridium and platinum plugs, ignitor and dunnydore coils and leads.
I think you need to replace all your parts with parts that fit the application that are strictly for the RB25DET NEO engine and then get it tuned.
If you cannot manage this then take it to competent mechanic who can help (most should be able to get you sorted.)
And make sure your base timing is set to 15 degrees on your CAS and plug gap is at factory 1.1mm as a start.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
