Hi all,
Can a bosch 044 fuel pump directly replace the stock intank fuel pump (in an R34 GT-R) or are there other fittings/modifications that need to be done to the 044 in order to successfully mount them in the fuel tank?
Cheers,
Edited by xanavinismo
https://www.sau.com.au/forums/topic/273877-bosch-044-fuel-pump/
Just remember if you replace the intank fuel hoses use Flouroelastomer outer hose. Regular efi will go to shit.
I am running an 044 intank in my 32 gtr, been great so far. You may also find these fittings usefull it's what I used:
Here
It allows you to come out at 90 from the pump outlet so you don't foul against the side of the tank. Has a pick-up as well. I looked everywhere for those fittings even Enzed couldn't do it, thread pitch on the 044's is not the norm which makes it hard.
Edited by James_03
Thanks a bunch for all of your replies guys. Although having read whats actually involved, I might end up getting a Nismo fuel pump instead because to my understanding, they are a direct replacement for the factory intank fuel pump and no modifying is required on R34 GT-R's?
Cheers,
ive got one in my 34.....there is no cradle on the 34.....its got a big rubber sleeve and clamp that holds the pump...its not quite large enough for the 44 pump....just use a hose clamp to hold it to the point where the original clamp goes....
you will also need a fitting to go in the intake to convert the pump to a barb so you can use the original hose and pick up filter...and one on the outlet to convert to barb....it works out it just runs straight in line as the original pump does....id say its the most simple gtr's to fit this pump to
Sorry to digress....is anyone having any surging issues with the intank 044 on track (circuit) days when cornering? If so what was your fuel level when this was occuring? I guess what I'm getting at - is it necessary to go to a surge tank setup for a bit of (safe) fun on the circuit?
It sounds like you are enjoying some of the oh so common overheating and cavitating problems that 044's do. A fuel cooler is meant to help quite dramatically, however it hasnt worked in my application.
It's something that I'm contemplating but just curious as to the pro's and con's of in-tank vs external vs external with surge tank.
If you mount in-tank do any problems exist as this would be the neatest way......but was wondering whether a dedicated surge tank was required for the odd treck to the circuit where G forces would be higher?
I have an s15 and can run my fuel down until the fuel light comes on without any fuel pickup issues at the circuit. Was thinking of upgrading my fuel pump (currently Nismo) to an 044 when I make the switch to E85. But was curious as to the best way to go.
I've nearly rear ended a few VR and VS Commodores at the circuit where they have fuel surge issues mid corner resulting in temporary engine shut down at the most inconvenient of places.
Here's a few setups I came accross on another forum:
http://www.freshalloy.com/forums/showthrea...fuel+pump+setup
Edited by juggernaut1
if you already have the nismo keep that, it flows the same if not more than a 044 assuming you aren't runny silly rail pressures.
I thought the Nismo was 4.1 litres/min or 246 litres/hour.................. vs the 044 at 300 litres/hour....no?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
