hi all,
a few months ago i bought a nismo gear knob for my car, but never kept it on there purely due to aesthetics!
its an r33 GTR, the gear knob is brand new and genuine nismo but it doesnt fit flush like it does on a 350z or a v35. (see pic)
when its on, you can still see part of the silver gear shaft / pole (if thats what its called?) underneath it. the knob doesnt cover all of it like the standard gear knob does.
has anyone else installed one of these in their car? is there a way of getting a shorter gear shaft / pole so you dont see the ugly silver bit!? is this a quick job? i'll be taking it to a mechanic to be done if it is possible.
any info or advice would be appreciated.
thanks!
I had a similar problem with my 33 and a nismo gear knob. Found the easiest fix it to cut a 3/4'' long piece of garden hose, force that down over the gear stick so the top of the boot is level with the last thread on the gear stick, then screw the knob on. should give it enough height to sit flush to the underside of the gear knob once on
i posted this in the other thread about the nismo gear knob
mines a r33 gts-t i think its the same
is this how yours sit?
i did something similar to above but instead i did it whilst the nismo knob was on and used blue tack to make it sit flush.
theres like this wedge thing inside the top of the gearboot which you need to make it sit higher to make it flush
heres example on my dildo knob which sits higher then the nismo knob which you'll see the gearboot is flush
Didn't get a chance to edit, but you remove the boot an plastic surround then put the hose on the gear stick. Just helps to hold the rubber collar in the boot a little higher.
I just wrapped a length of electrical tap around the shaft (about 2mm below where the knob finishes) to thicken up the shaft. When done force gear stick surround up and over the electrical tape and it just sits there all perfect :bunny:
You're in Sydney? Should join SAUNSW.
The best way IMO to fix this is to get a cable tie on the underside of the leather at the top of the shaft, tie it up from underneath the leather boot (means taking off some trim for a minute or two) :)
Depends which size you bought, on the packaging it should say either 10mm or 12mm.
10mm knobs are for 5MT cars - R32s, R33s and R34 GT-ts
12mm knobs are for 5MT cars - R34 GTR's S15's
Hope that helps
ps. cool car! i think im a R33 GTR convert in terms of GTRs
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
