As above, my shift lock has a problem and is hard to get out of park. Even when i start the car its not releasing to go into drive.
Yes i have put my foot on the brake, and have tried turning the car on and off and releasing + pressing the brake.
I can hear the 'click' in the shifter when i press the break but its like the shift lock isnt releasing??
So does anyone know if the shift lock is adjustable if so how???
Also would it be a problem within the gear shifter thats not working???
Thanks
https://www.sau.com.au/forums/topic/274020-shift-lock-problem/
Took car to mechanic today and solved problem.
It was the cable running from the shifter to the ignition which is a 2nd lockout for the car.
The series 2 Stageas have a button to override the ignition shift lock however the S1's works of the ignition so the mechanic just disconnected the cable and lockout plastic switch from the ignition and all done!!
Shifter doesn't stick anymore and the 'brake lockout' is still in place.
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
