Hey guys, was wondering if you could help me and a mate out. We are unsure as to whether his Silvia (Q) has a CA18 or a SR20. So I was wondering if I could borrow your knowledge and help us out :) Here are the facts:
It says 2 litre on the engine casing.
It has SR20 on the sticker on the under side of the bonnet.
It says CA18 on the metal stamp next to the import stamp.
It is a 1991 model. (I think, it may of been imported in 1991)
We are unsure which to believe, the company in which he bought it from said it was a CA18 so it doesnt matter if it is, he didnt get ripped off or anything, we are just interested.
Cheers for any help in advance :)
https://www.sau.com.au/forums/topic/27412-is-it-a-ca18-or-a-sr20/
mad max:
Is the boot badge a circle or more square?
The SR20's have a circle, the CA18's have more of a square boot badge.
Also the SR20's have round halogen lights (99% of the time) and the CA18's have the better looking square headlights.
dkonig: Be careful not to spread misinformation.. SR20's have a red rocker cover, CA18's should have a silver one.
To confuse tihngs even more, it might be a CA18 with an SR20 Engine dropped in it. :)
But yes, '91 models and above are SR20's.. And no, it would have certainly not been imported in 91.
I have not spread any mis-information, the third silver rocker covered SR20DE I have owned is parked in my driveway.
silver rocker cover with distributor rather than coil packs is from S13 Q
S13 K had the red cover and the coils
LATE S13 K had the blck rocker cover with coils but NO VVT (not sloped at the back of the cover)
S14 had the black cover but sloped at the back for vvt
S15 sort of grey colour, also sloped at back
Attached a pic of my DE (and yes I know thats a turbo on it :)
CA18DE were all Red Rocker covers except for a CA18e which was a carby smaller version of the R31 pintara motor CA20e, the ca18e which had a silver rocker cover, but this motor was only ever a Single overhead cam jusst like the CA20e.
Guest Sphyncter
ive got a ca18de red rocker silvia. dont worry about the badging and stuff cause thats no good to ya. you should be able to go from the metal stamp (next to import stamp) because these are meant to be changed whenever engine is changed (duh!) because it should have engine number on it and stuff. i know mine has had a 2L in it at some stage, but its back to the 1.8. check the metal badge, if that says 1.8 then id say its 1.8. as the guys said, without a pick we can't help ya.
as for headlights guys, mines an 88 and its got the round globes, not the square!!
-Pat
And this has been my 2 cents.....
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
