Swiper the Fox Posted June 10, 2009 Share Posted June 10, 2009 I have access to 5 Nitto oil pumps for RB engines. These pumps are individually assembled, set-up and tested. They use the latest generation world class materials. Pumps are being sourced locally through Croydon Racing Developments and are now used in all of their big engines. price is $1250 delivered. This is a huge saving over the comparable Japanese items. please register below. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/ Share on other sites More sharing options...
Blitz Posted June 11, 2009 Share Posted June 11, 2009 Paul, please confirm the start and finish date for this group buy, as well as the name of the business supplying the pumps. Thanks. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4649498 Share on other sites More sharing options...
Swiper the Fox Posted June 11, 2009 Author Share Posted June 11, 2009 Paul, please confirm the start and finish date for this group buy, as well as the name of the business supplying the pumps.Thanks. look at the above post it clearly states CRD are the supplier. Lets say group buy is open for 8 weeks from date of original post. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4650338 Share on other sites More sharing options...
Blitz Posted June 11, 2009 Share Posted June 11, 2009 Thanks mate, as you were Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4651425 Share on other sites More sharing options...
Icekallt Posted June 12, 2009 Share Posted June 12, 2009 I have access to 5 Nitto oil pumps for RB engines. These pumps are individually assembled, set-up and tested. They use the latest generation world class materials.Pumps are being sourced locally through Croydon Racing Developments and are now used in all of their big engines. price is $1250 delivered. This is a huge saving over the comparable Japanese items. please register below. Do you have any more info about them? //Peter Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4653423 Share on other sites More sharing options...
T-Rex Posted June 13, 2009 Share Posted June 13, 2009 Do you have any more info about them?//Peter This place has a few photos up and a little info, not much, but you get the idea. It would be my choice of pump.. http://www.tweakit.net/shop/product_info.p...roducts_id=7204 Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4654221 Share on other sites More sharing options...
BOZ22N Posted June 14, 2009 Share Posted June 14, 2009 More info about the pump would be nice. Cheers, Ryan Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4656483 Share on other sites More sharing options...
Swiper the Fox Posted June 15, 2009 Author Share Posted June 15, 2009 RB SERIES HIGH VOLUME OIL PUMP The NITTO RB series high volume oil pump is a high quality and performance aftermarket oil pump that will suit Nissan RB20, RB25, RB26 and RB30 engines. Oil flow and pressure is dramatically increased over that of the factory oil pump which is critical in modified engines for reliability of the lubrication system. Failure of this system is the “achilles heel” of the Nissan RB series engine even on lightly tuned examples and accounts for a high percentage of engine failures. Factory and factory based oil pumps are highly prone to oil pump gear failure in modified engines due to the quality of the cheaper mass produced material used for the manufacture of the gears. Oil pump gear failure will result in indefinite engine damage. For this reason EN26 ball bearing steel is utilised for the manufacture of NITTO RB series high volume oil pump gears which are superior in strength and durability to that of both factory and its competitor’s oil pump gears. NITTO RB series oil pumps are supplied pre-inspected, blue printed, assembled and cleaned to enable direct installation strait onto your engine and assure total confidence. Detailed list of components: Gears: Material: EN26 ball bearing steel Housing: Quality alloy casting Technical Specification: Pressure relief valve crack off (dual springs): 120 psi * Pressure relief valve crack off (outer spring only): 75 psi * FLOW (LITRES / MIN) ENGINE RPM FACTORY OIL PUMP NITTO HIGH VOLUME OIL PUMP 750 4.6 6.5 2200 15.3 20.2 7000 46.5 64.8 Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4656850 Share on other sites More sharing options...
BOZ22N Posted June 15, 2009 Share Posted June 15, 2009 TA Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4656875 Share on other sites More sharing options...
OJR32 Posted June 16, 2009 Share Posted June 16, 2009 I will take one You have email at dgarage Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4659722 Share on other sites More sharing options...
Swiper the Fox Posted June 16, 2009 Author Share Posted June 16, 2009 one down four to go! Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4659823 Share on other sites More sharing options...
ahh 33 s2 Posted June 17, 2009 Share Posted June 17, 2009 1 please mr dirt. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4662583 Share on other sites More sharing options...
Swiper the Fox Posted June 18, 2009 Author Share Posted June 18, 2009 1/OJR32 2/ahh 33 s2 3 left come and get them. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4665596 Share on other sites More sharing options...
Swiper the Fox Posted June 23, 2009 Author Share Posted June 23, 2009 (edited) 2 left...this is the only time this price will be offered. Edited June 23, 2009 by DiRTgarage Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4674917 Share on other sites More sharing options...
ahh 33 s2 Posted June 29, 2009 Share Posted June 29, 2009 has mine been sent or waiting to sell all 5?? did u recieve my payment??? Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4686176 Share on other sites More sharing options...
Swiper the Fox Posted June 29, 2009 Author Share Posted June 29, 2009 (edited) has mine been sent or waiting to sell all 5??did u recieve my payment??? no yours has arrived and will be sent to you tomm. you have pm thanks Edited June 29, 2009 by DiRTgarage Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4686505 Share on other sites More sharing options...
55Nat Posted July 21, 2009 Share Posted July 21, 2009 just seeing if thes pumps are still available? if they are im keen for 1 please. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4727439 Share on other sites More sharing options...
Swiper the Fox Posted July 21, 2009 Author Share Posted July 21, 2009 you have pm...if nathan takes this one there will be only 1 left....then group buy will be closed. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4727547 Share on other sites More sharing options...
55Nat Posted July 29, 2009 Share Posted July 29, 2009 DirTgarage you have PM. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4738714 Share on other sites More sharing options...
Swiper the Fox Posted July 30, 2009 Author Share Posted July 30, 2009 one left guys. Link to comment https://www.sau.com.au/forums/topic/274126-nitto-rb-series-oil-pumps/#findComment-4741698 Share on other sites More sharing options...
