FS: R33 GTS25t S1. Manual. This car was featured in HPI Magazine 2008 then having a RB26/30, the original RB25DET has since been put back but with many of the RB30's bolt on's have remained. Has not since been dyno'd so cannot give a figure but would suggest well in excess of 200rwkw on current boost of 7psi. Has following mods:
-HD Clutch
-Malapassi Rising Rate fuel Reg
-Stainless surge tank
-700HP Rated Bosch 044 Fuel pump
-Trust front bar
-Trust Front Mount Intercooler w/ stainless piping
-GReddy Profec B spec II Electronic Boost Controller
-Microtech LTX12S ecu
-Microtech dash
-Apexi Pod filter no AFM
-GFB Trumpet Blow off valve
-HKS Billet Oil Cap
-Tomei Gear Knob
-Personal Steering Wheel
-Stainless oil catch can
-Turbo timer
-3" stainless exh.
-Blitz Nur spec muffler
-Autometer gauges, boost, oil and tacho w/ shift light (oil and tacho not hooked up as i read off the Microtech dash)
-17" deep dish lightweight wheels
-Sunroof
-95% black windows
-Bendix ultimate brake pads
I'm currently driving the car and it's spot on but will need a few minor bits done for RWC, please note that this car has had the A/C removed so if you live in a hot climate you may want to put it back on, however it saves a lot weight and I live in cold Victoria so doesn't worry me. Un-abused weekend driver and very clean for age and price. VIC Rego till Dec 2009.
**** Plates not included****
$14K
Ph: Miles 0414224905
https://www.sau.com.au/forums/topic/274475-1993-r33-gts-t/
  • 1 month later...
you ınterested ın a swap wıth cash my way?
the lınk ıs http://www.skylinesaustralia.com/forums/R3...od-t278827.html
cheers, taner
Nice GTR, unfortunately not interested in part swapping for a GTR at this stage.
https://www.sau.com.au/forums/topic/274475-1993-r33-gts-t/#findComment-4712219
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
