FS: R33 GTS25t S1. Manual. This car was featured in HPI Magazine 2008 then having a RB26/30, the original RB25DET has since been put back but with many of the RB30's bolt on's have remained. Has not since been dyno'd so cannot give a figure but would suggest well in excess of 200rwkw on current boost of 7psi. Has following mods:
-HD Clutch
-Malapassi Rising Rate fuel Reg
-Stainless surge tank
-700HP Rated Bosch 044 Fuel pump
-Trust front bar
-Trust Front Mount Intercooler w/ stainless piping
-GReddy Profec B spec II Electronic Boost Controller
-Microtech LTX12S ecu
-Microtech dash
-Apexi Pod filter no AFM
-GFB Trumpet Blow off valve
-HKS Billet Oil Cap
-Tomei Gear Knob
-Personal Steering Wheel
-Stainless oil catch can
-Turbo timer
-3" stainless exh.
-Blitz Nur spec muffler
-Autometer gauges, boost, oil and tacho w/ shift light (oil and tacho not hooked up as i read off the Microtech dash)
-17" deep dish lightweight wheels
-Sunroof
-95% black windows
-Bendix ultimate brake pads
I'm currently driving the car and it's spot on but will need a few minor bits done for RWC, please note that this car has had the A/C removed so if you live in a hot climate you may want to put it back on, however it saves a lot weight and I live in cold Victoria so doesn't worry me. Un-abused weekend driver and very clean for age and price. VIC Rego till Dec 2009.
**** Plates not included****
$14K
Ph: Miles 0414224905
https://www.sau.com.au/forums/topic/274475-1993-r33-gts-t/
  • 1 month later...
you ınterested ın a swap wıth cash my way?
the lınk ıs http://www.skylinesaustralia.com/forums/R3...od-t278827.html
cheers, taner
Nice GTR, unfortunately not interested in part swapping for a GTR at this stage.
https://www.sau.com.au/forums/topic/274475-1993-r33-gts-t/#findComment-4712219
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
