I got stickered :D
Cops reckon my exhaust is less than 100mm from the ground so *slap*!
i needa take my screamer and de-cat out, adjust my ride height and i needa ask
Can i borrow someones standard rims with decent tread for pits? Will be going over next week and i hope i don't get royally raped :)
Cheers :D
https://www.sau.com.au/forums/topic/275292-stickered/
  • Replies 70
ah dont stress yourself about it. I got done for the same thing recently. I got an awesome inspector at Welshpool and he passed me with heaps of defects still on there. At the end of the day you should prepare for the worst and hope you get a nice inspector.
Have you checked that the exhaust hieght is ok. The cops gave me a flick knife to test my exhaust height. It was probably 80mm from the ground
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4664124
^^WHS
100mm from the lowest point with a fully loaded car, so if your at 110mm you might still be considered a little too low by the cops.
Also something like 400-500mm from the lowest point of the headlights or something, I never pay much attention to that one.
Basically, if its lowered enough to look good its too low.
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4664665
I'm pretty sure it does, had a few mates fail because their kits scraped.
I've also heard that even a wire hanging down counts, because if it's for a fuel pump or something, it rips going over a speed bump, the car will suddenly be inmovable causing headaches for everyone. That's what I've heard anyway.
Point is, kits are included in the too low rules.
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665426
Yer i work at DPI, but that doesnt mean i will get a nice inspector.
Rhys - yeah i have coilovers and will just wind 'em up and take my screamer and de-cat pipe out.....might come cruising tomorrow night not sure yet
ADR rules state the you are not allowed to have different rim width front & rear unless your car came with different rim widths from factory.
Anyways, cheers for teh replies, i'll get back to you tomoro, im sleepy now :D
hehe ciao
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665584
Stick with the 100mm from the lowest point of the car rule nic, otherwise fools with 20" rims on their fully sick honda accord Si's that are FAR too low will be more legal than an dumped XA falcon (for instance) with standard 12-slotters.
mates escort pano's lowering block u-bolts were 120mm from the ground, and had like 14x8 custom jelly beans. coppers sent him on his merry way. cop measured a brick that he found to around 100mm and stuck it underneath...
gotta love country cops. normally don't spell it with an 'o', but 'flamin mongrelry' cops doesn't make sense.
Edited by Dorigecko
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665609
Yeh, when it comes to ride height, 100mm is the lowest point of the car. That's for everything (kits, cats....mmm kit-kats).
My mate just took his R33 over the pits and he got failed on his rims being too big (R33 gts-t with 19x8.5s all round), and having a spoiler on the boot but not having a brake light in there (as u need a brake light at eye level so they). However, i have taken the spoiler off my car, as you know Rhys.
I might come just to the meet point tonight for the cruise....im sick as a dog atm so i'll see
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4665975
Unlucky man, I almost got yellowed the other day cause the cops were saying my tyres were to big.....lucky for me it started to rain and they went 'f**k it' :down:
Sorry to highjack, but.....
Are 235's on the front and 255's on the back to large for a R32 GTS-T??
I mean, it is right on the guard, and may even stick a mil over....
Edited by Douse
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4666065
Yeah Id say it is.
What are the widths of your wheels?
Your not supposed to go with anything much wider than the widest that came with that car.
So you can argue that the GTR came out with 8" wheels and try get away with say 8.5"?
Any wider and it's too wide unless you get permits/engineers.
Sad but true.
https://www.sau.com.au/forums/topic/275292-stickered/#findComment-4666116
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
