Okies, price drop on a few things... GT30 Turbo $650
Sub $200
Sub box $80, still pick up only!
Drivers side R33 headlight $100
Come on guys! Could really use the cash!
umm... dude
that "vg turbo"is a STOCK rb20 turbo...
notice on the front housing how it says "16v".. THATS STOCK RB20.
VG30 and RB25 say 45V...
just a headsu p when the guy wants his money back :cool:
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
