atomaly Posted June 19, 2009 Share Posted June 19, 2009 (edited) i've had a head unit installed so far. Alpine ida - X305 i've got an Alpine 10" type R sub in a box that my mate is gonna give to me. wondering what amps to get.. i was hoping to install the amps in the side compartments in the back where the factory CD stacker goes (i didnt get one tho ) or in one of the lift up compartments in the back. i dont want to be mounting anywhere custom as i cringe about someone hacking at my interior. the easier, the better so far i was thinking of getting an Alpine MRP-F300 for the speakers (not changing them as of just yet) and an Alpine MRP-M500 for the sub will give me a bit of extra bass thats tight cos thats all i'm looking for at the moment. i'll be having the sub set up against the back seats i think. any ideas from anyone ? do i need to go that far with 2 amps? or is there an easier option for some extra bass. i might have a go at installing it myself..... although i'm sure i may need some help Edited June 19, 2009 by atomaly Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/ Share on other sites More sharing options...
infiltrator Posted June 19, 2009 Share Posted June 19, 2009 better change the speakers, especialy if you have the factory ones, they wont handle the extra power of a power amp. any help you need just ask mate, im in preston and work in port melb, just let me know Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4666749 Share on other sites More sharing options...
atomaly Posted June 19, 2009 Author Share Posted June 19, 2009 better change the speakers, especialy if you have the factory ones, they wont handle the extra power of a power amp.any help you need just ask mate, im in preston and work in port melb, just let me know thanks man i'm only going to be running the factory speakers until i can afford some alpines or something. so u say for the moment just get the mono amp and run the sub? and get the other amp when i get the new speakers? Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4666850 Share on other sites More sharing options...
too_much_boost Posted June 19, 2009 Share Posted June 19, 2009 Why not get a 5channel? Jaycar sell digital 5 channel amps that will run your whole system and can easily fit under either of the front seats (Good for keeping thieves away) I have one of their digital 4 channels under my seat running my front MB Quart 6.5in splits and my cadence sub and it does a mighty fine job Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4666852 Share on other sites More sharing options...
infiltrator Posted June 19, 2009 Share Posted June 19, 2009 Why not get a 5channel? Jaycar sell digital 5 channel amps that will run your whole system and can easily fit under either of the front seats (Good for keeping thieves away)I have one of their digital 4 channels under my seat running my front MB Quart 6.5in splits and my cadence sub and it does a mighty fine job thats a great idea too, means 1 amp and everythings done... less wiring to worry about, no power distros and the like. My set up in the stag is rather big, 2x Alpine MRD-M300 mono amps running the 2 Type S 12" subs, 1 x Alpine MRV-F540 4 Ch running the front splits (Active, 75W into each woofer and tweeter) .. Fronts are Focal polyglass 165's upgrades are a few more amps, 1 for the 8" Mids that are going in the doors and 2 for the 5" Subs that will be going in the front foot wells Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4666969 Share on other sites More sharing options...
_Ryan_ Posted June 19, 2009 Share Posted June 19, 2009 pop by Stylyn in Boronia, they have a great range and do great work, Alpine make a 5channel, its tiny too! Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4666979 Share on other sites More sharing options...
infiltrator Posted June 19, 2009 Share Posted June 19, 2009 also check out http://www.mobileelectronics.com.au they can have good bargens in there for sale section. Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4667014 Share on other sites More sharing options...
Chris Rogers Posted June 19, 2009 Share Posted June 19, 2009 pop by Stylyn in Boronia, they have a great range and do great work, Alpine make a 5channel, its tiny too! +1 Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4667064 Share on other sites More sharing options...
atomaly Posted June 22, 2009 Author Share Posted June 22, 2009 thats a great idea too, means 1 amp and everythings done... less wiring to worry about, no power distros and the like.My set up in the stag is rather big, 2x Alpine MRD-M300 mono amps running the 2 Type S 12" subs, 1 x Alpine MRV-F540 4 Ch running the front splits (Active, 75W into each woofer and tweeter) .. Fronts are Focal polyglass 165's upgrades are a few more amps, 1 for the 8" Mids that are going in the doors and 2 for the 5" Subs that will be going in the front foot wells sounds like a good idea.. i'm having a look at the new range.. the Alpine PDX-5 is a 5 channel but the output for the sub is only 2 ohms?? huh? i thought 4 ohms was standard for car audio? the Alpine MRV-F450 V12 also sounds like a good option. its 5 channel 4ohm. its discontinued but i may be able to pick one up second hand!.. i presume though that the newer amps would be "better" though in most aspects?? i also had an opinion to just get a 4 channel amp. bridge 2 for the sub output and go for high quality splits in the front. since my rear door ones are probably no point having since i barely have rear passengers! home audio is so much easier amp: Yamaha receiver. fronts: Aaron Ats-4 Centre: Aaron CC-120 rears: Aaron Ats-3 samsung series 6.. 46" HD LCD TV seeeeeeeee i'll prob pop into Stylyn on a weekend when i get some free time see what they think Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4671967 Share on other sites More sharing options...
infiltrator Posted June 22, 2009 Share Posted June 22, 2009 subs are either Alpine subs now are either Dual 4 ohm or Dual 2 ohm, the dual 2's are good if you have got the amps to run an either 2 or 1 ohm loads, the dual 4's are nicer for normal guys that arent into SPL. i think ill be running 4x dual 2ohm. in a series parallel system... big bass also try Garry's car radio Heidleberg, and GL Pro sound in essendon for price comparrasons. Link to comment https://www.sau.com.au/forums/topic/275431-audio-for-the-rs4s/#findComment-4672131 Share on other sites More sharing options...
