Hey guys,
Im in the process of putting together the SK Gb setup for my 33 and so for have the complete Camber/Caster Kit and Pineapples (Not installed yet) and I was measuring up the ride hieght the other day to discover 260mm front and 350mm rear centre of wheel to guard hieght.
Now Ive always thought my line sits a little lower than most so is there such a thing as Factory lowered suspension on the 33 GTST???
Im fairly sure that I have factory suspension but not 100%
The suspension travel still feels fairly tight so I dont "think" it is past its use by date but again im not sure
Car is 98 GTST with 100k (Genuine with books)
Hey guys,
260 mm front, I don't think so?
Standard (new) height is 375 mm front and 365 mm rear, settling 15 mm from standard is not unusual.
Cheers
Gary
GTR V-Spec's factory suspension are generally lower than the normal GTR's. Check your VIN through Nissan FAST, might shed some light on the suspension.
Eh, 15mm in 100kk's isn't "sagging", it's well in the region of "acceptable settling". :P
Cheers
Gary
Thanks SK looks like I still have a bit of time to get new gear. As I said earlier it still feels very tight and the car has been meticulously looked after since ive had it so I wouldnt think they are shot.
As long as they will hang in for at least this year ill be happy.
Now to just put the camber and caster kit on
Thanks again for the advice
Cheers
Gary
true, 350 is still legal (at the limit), and 360 is well over legal for the front. if he wasnt gonna buy new stuff anyway, you'd probably get away with it. last thing u want however is to get defected for being a few mm too low with stock suspension because u just put in a full tank of fuel. so honestly there isnt a lot of point having stock suspension if theres still a good chance of getting defected anyway.
Unless I'm mistaken he's in NSW, we don't have ignorant Nazis doing rego here like you do in SA. We actually follow the ADR's, which means 345/335 is OK as long as it has a well designed 3" exhaust and the bump stops have been trimmed.
Cheers
Gary
Cheers
Gary
is it 345/335 over there? bastards. its 350/340 here, i thought that was universal for all states.
SA may have nazi's, but technically if the car is a few mm before 350, it is illegal and against the ADR's.
There are basically 3 relevant ADR's;
500 mm headlight centre from the ground.
100 mm minimum ground clearance.
2/3rd suspension travel retained.
The 500 mm headlights is never a problem for a R32/33/34, because the engine subframe would be scraping on the ground if the headlights were 500 mm or less. Even standard length shocks don't have a problem with retaining 2/3rd the travel at 345/335. Then there are the options of lower profile strut tops and shorter shocks if necessary, remembering that 2/3rds is metal to metal.
The one that causes the most problem for R32/33/34's is the 100 mm minimum ground clearance, as the exhaust goes under the rear subframe. So a car with a 2.5" exhaust of decent design would have no problem with clearing 100 mm at 345/335. Even a 3" usually makes it, it's when you get to 3.5" and 4" exhausts that 345/335 isn't possible, there simply isn't enough room to fit that diameter exhaust under the subframe.
So the simplistic Nazis that say 350/340 is the ADR height are completely incorrect, there is no such measurement specified. The fact is I could have one at 320/310 that fully complied with the ADR's, if I used the appropriate parts, oval exhaust, short shocks and low profile strut tops.
Cheers
Gary
ahk, over here in SA the eyebrow height is the first thing they go for.
http://www.skylinesaustralia.com/forums/post-a192357-
it's actually 355 and 345 for the R33/R32. so technically it would be illegal. but if they dont check for that over there then ur in business.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
