hey all i am after a drift car doesnt have to have rego.
im located in melb and looking for something close.
the car must be turbo and small/light damage doesnt bother nothing too big
show me what ya got what one as cheap as possible.
thanks Dean
https://www.sau.com.au/forums/topic/275692-wtb-drift-car/
i have a skyline r34 2 door , black , with all new running gear , hks cams , hks cam gears, metal head gasket, greddy Turbo T67 -25 G , top mounted and external gated, new r34 gear box with new OS giken twin plate clutch, new 2 way mechanical diff , as well as HKS coil over suspention, hks front mounted oil cooler and intercooler, has all the usall stuff like full exhaust and surge tanks , car has run 11.4 and 118 mph at calder , very responsive , im in melb and selling for 17500 the lot , car can be complianced as i hold the import appoval
https://www.sau.com.au/forums/topic/275692-wtb-drift-car/#findComment-4669952
got a s13 drift car just got imported from japan
its a 88 model so its a modded CA18det
its got the works for a cheap drift car, IRS Turbo, 2Way Nismo diff, twinplate clucth, Hks FCON V Pro Computer, BlTZ Boost Controller, Cusco rear Camber Arms, JIC Coilovers Front n Rear, 18inch Wheels, FET CoilPacks, Hks Intercooler, R32 GTR Injectors, Sparco Front Seat, R34 Gtr Fuel Pump Plus More
Only Problem paint is ruff from the sun and abit of surface rust nothing major
plus More Give me a call on 0433 180 308 (PJ)
https://www.sau.com.au/forums/topic/275692-wtb-drift-car/#findComment-4671155
hey mate im from central coast nsw if not to far got 2 r33 skylines avilable one i just advertised on in the forsale section and the other is more of a street car has body is perfect with body kit and looks great feel free to contact me on 0411672105
https://www.sau.com.au/forums/topic/275692-wtb-drift-car/#findComment-4671325
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
