Hey all,
Going back to stock bumpers on the ceffy so chucking my genuine Final Konnexion (http://www.finalkonnexion.co.jp) kit up for sale.
Its a bit rough from wear but sides and rear fit perfectly, problems are:
  • Front bumper has been broken and re-glassed so fit isn't perfect, have to pull in under indicators like with most bars
  • Passenger side skirt has the 'triangle' part broken off at the rear, shouldn't be too hard to fix and still bolts on perfectly
  • Rear bar has a weird crack in the paint on the drivers rear corner, but otherwise is perfect
Located in Melbourne and wont post due to size. Asking $800 or something reasonable as it is a genuine kit, regardless of wear and tear :D
I can be contacted on 0412 033 449 or via PM. Pics to come...
Cheers.
https://www.sau.com.au/forums/topic/275851-cefiro-final-konnexion-kit/
lol i found ya add haha...
ur kit looks pretty much the same as mine, i was thinkin about gettin an autech front kit.. but i dont know where to get it from
This kit looks so much better in real life!! It is TRULY one of those cases where "the pics dont do justice"
If I still had my Ceffy I would have definetly considered buying it, looks so Phat!!!
oh so tempting! i'll pm you if i find the $$ :(
Plz do, its going in the garage as soon as I get a stock rear bar.
Maybe we could swap? $550 if you give me a stock rear bar :) :) (although you have to get it home)
Edited by konect
  • 1 month later...
Man I shelled out $2200 for this Kit.
"Weird Crack" on the rear bar happened when I had the kit, i cant remember what happened... i think i backed the car into a plant or something at work :D
PS all the "alterations" on the kit had to be made to make it fit originally... ie repaired to make it fit - as the fitment was subpar.
JK
  • 4 weeks later...
can i haz front bar, i'll swap with my stock one + cash ur way lol??
Haha I have a front bar!
Guys im still trying to get rid of this thing as its gathering grass on the lawn!
$400 + a stock rear bar or $500 take it away
DO...IT.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
