Ben,
Shane is off to Japan tomorrow, and I'm off to PI the day after. Let me sort this out on my return Tuesday next week? Got too much on my list atm. But put me in, for now, as a maybe for already having my own accommodation, a maybe/yes for the saturday brekkie.
Cool man, will I add +2 for your lil lady and the young fella ?
-D
  • Replies 714
Posted Images
Cara does have both the flags and the sau banner, however she doesnt know when/if she'll be around for us to pick up said items. The best I could get out of her via MSN tonight was to call her the day before the event happens and then we drive to wherever that is, and pick up the items.
Brings me to the next point, I know some are staying for the sunday cruise, who will need a 2nd breakfast the next day? I got a bunch of people down for the sat morning, so if u add yr names to the sunday it'd be just as easy (and cheaper)....
Also, i'd like to know how Troy (Sapphire), Ruby and Shane are going in regards to accomodation; will u guys want a detailer and will you want sat or sun brekky and for how many people ?
Let me know folks - I hate asking the same questions over and over again.
-D
Ben put me down for the sunday breaky as well mate....with all my special needs lol
Thanks mate
Thanks mate
BREAK FAST SIGN ME UP :(
Same here, also for my mate aswell.
I am still thinking about the car detailing, i shall see in the next few weeks what happens, as i may do some before i head up.
Yeah we've only had 4 people express interest and Im afraid we'd probably need more demand to justify the travel for the bloke, so I guess we'll just have to do our own detailing when we get up there - no reason you cant get a job done in adelaide beforehand
-D
oh on that note....Ben you would find that my form and $ has been forwarded as Cara had those a while ago....
Will PM cara to make sure she has forwarded it on
Yep, She'd confirmed earlier that you and Abe have already paid
I'll mark u down as paid Dion
-D
I can't be bothered searching back pages, but what does this breakfast include Dohmar?
Cheers
First we feed krishy baked beans and eggs and then we throw him on a spit and have krishy yiros
jk
bacon, eggs, sausage, tomato, bread, onion, mushroom, etc - english breakfast - without the black pudding cause that shits gross
-D
Can I have one for Sunday minus egg, tomato, onion and mushroom.
Cheers. Will need hangover food haha
Pretty much the cost of $5 per brekky covers everything - whether u want the extras or not is fine, as people who eat less meat tend to fill up on the other stuff, everything works itself out...
-D
EDIT : No Egg? And you call yourself an aussie? Sheesh (Forgot to mention there will be baked beans too for the vego communist hippies)
As I said to Ben on the phone I am most happy to supply my basic shade like we used at Kadina, but then thought about this:
http://www.dealsdirect.com.au/p/white-part...-walls-windows/
If we all chipped in and bought this, then SAU would OWN it. So a once-off donation from the people going of about $15 and it can be used for future events for free. Looks pretty awesome, is much bigger than mine (and presumably properly waterproof), and has side and rear protection.
I reckon this is the way to go! With the number of people about the place on the day we can put up this thing in around 10 minutes flat. Would be tons of space too - 6m x 3m is HUGE.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
