  • Replies 174
Abe join in and race. I havent got a partner yet :(
Sorry, even though its only $50-$60, i don't have the money atm. Been spending too much on my car.
Im racing :rant: Dan (inline 6) has jumped on the bandwagon for a team mate. :D
Watch out mofo's haha
At least you got a racing partner, good thing he is going, i can ask him to do my tax while he is there :rant: .
Congrats on Scotty and myself winning :P
Bad luck all you losers who didn't come out for drinks afterwards - Scandy and I rolled the Belgian Beef Cafe and perved on all the hotties - and dayum were there many!
Plus spotted a pair of bayside blue R34GTRs outside the Belgian, and then a silver R34GTR, Ferrari Testarossa and a Maserati shortly thereafter.
Not to mention a dodgy 4wd patrol driven by MattyT and containing none other than Flick, SkylineGuy19 and the rest of the crew :)
Top organising skillz Kirshneel Mohammed, and I advise everyone who came that I will organise paintballing in the very near future - so stay tuned!!!
brilliant, paintball. much more my style. im really starting to hurt now that im home. faaaark. need to make a seat suitable for fat flamin mongrels. honestly.
but yeah, as andrew said, post-karts beer was f**king win.
and roo, man... all that grandstanding and you still didnt win...? c'mon.
and thanks to adrian for taking the extra laps, i was f**king destroyed. wasnt feeling good at all after those hits on my third sesh.
Edited by scandyflick
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
