Hi Guys,
Buying an Apexi AVCR very soon.
Just want to know if i can hook up an external switch (i.e. not by pressing a switch on the avcr face) to change between hi and low boost?
My idea is to have a switch on my dash which allows me to run low boost, then when i punch this switch the AVCR switches to high boost setting.
Does anyone know if this is possible?
Cheers
https://www.sau.com.au/forums/topic/276576-apexi-avcr/
Excuse the incorrect use of language, but you dont want to use a missile switch. The AVC-R has two boost settings so yo ujust go to the setting you want to run. A missile switch is a two pole( Language???) switch . You want a sinle contact button so that only whilst pressed it will complete the circuit thus giving you the scramble
I have a button on my old steering wheel for it. Though i never really had enough power to justify using it. I actually used it to drop boost with the scramble feature. So when launching in 1st gear i only had 8psi then in the higher gears i used to use the normall Setting B high boost setting of 15psi on my std turbo. Like i said never really had enough power to justify using it that way, maybe make use of it now that i have more power but i dont run it anymore :(
https://www.sau.com.au/forums/topic/276576-apexi-avcr/#findComment-4682595
whats the point? why not just tune the car for the maximum possible safe boost you can run
and use the avcr tuning ability to curve the duty to correct wheelspin etc
most people break things when their car is setup for a safe level
and they have a switch to go higher "for short runs"
if you run higher, why not run higher all the time
https://www.sau.com.au/forums/topic/276576-apexi-avcr/#findComment-4682608
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
