Hi guys I would just like to know if the GTR Plenum will fit a RB25???? if not dose any one know of any cheap aftermarket Plenums to fit a 25??????
Charlie, I would suggest you use the search function as both of these have been covered quite recently.
The multi throttle body rb26 plenum is not a direct bolt on fit but thge head can be modified to make it fit.
There are forward facing plenums that you can buy to replace the stock plenum. I remember reading a topic recently on someone who created a how to with photos on it.
have a look around on ebay - there are plenty of options for an aftermarket rb 25 plenum. You can modify the std plenum so that it is forward facing, however its not recommended to do so as the design of the std plenum with the intake in the middle is better for distributing air evenly into all the cylinders. By modifying it to be forward facing you will find that cylinders 5 and 6 will not get the same amount of air as cylinders 1 and 2, resulting in the AFR mixtures to be uneven and possibly resulting in long term damage to the motor.
Best option is to go a greddy or similar plenum, or any other brand, as long as it is tested for air flow and the design and workmanship is of an excellent grade with good quality joins and runners.
Keep us posted on what u end up getting and what sort of figures it makes and also whether having an aftermarket plenum makes a noticeable difference in the curve or driveability of the car.
Cheers mate :P
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
