Guys, the day i thought never would come has, i think. Crusing down portrush rd today. Temp spiked to 100 degrees. pulled over instantly. split hose on the rear of the plenum, right at the back on the bottom. inside radiator has that unmistakable carbony smell.
Just need some advice.. should i fix the hose.. then take it to get diagnosed?? or just take it somewhere straight away??
help!! dan
https://www.sau.com.au/forums/topic/276694-r33-gtr/
help!! dan
Fix your coolant leak good and proper. Fill with quality coolant and idle until warm. Shut down engine and let it cool. Once cool check the contents of the radiator. If its low and your oil dipstick looks like a chocolate milkshake, then I'd worry about getting the head pressure tested and machined to be level. If coolant level okay and oil normal, still run a compression test to ensure no compression leak as a result of the overheating.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4682539
yeah mate pretty much what ruby said....i am pretty sure that coolant hose would be running to the turbo (dont kill me if i am wrong here) if it still has a stock setup.....if thats the case then get it fixed, and do what ever ruby said so nothing to worry about the car motor wise anyway
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4682768
yeah thanks guys... still pretty devo its happened. at least its not oil starvation. gonna pull the plenumn off tom.. order all hoses monday. then put it to the test. cheers again guys.
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4682782
from memory as well to replace that hose mate you will most likely need to drop the gear box (well on a 25 you have to anyway).....goodluck getting it fixed....also if you can afford it get it done by a reputable workshop mate
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4683345
gtr's are completely different to the 25's krishy...your making it sound worse than what it is.
Replace the hose. Fill with coolant and bleed all air out of the cooling system and run with heater on while topping up coolant in radiator. Once at normal operating temp...put cap on, take for spin around the block and see how she runs. Dont thrash it. Load it up a little bit, then check coolant after it's cooled down. Dont rip cap off straight after you've returned from your drive as you may get burned.
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4683379
lol answers my question, thanks ryan....i figured that they would be different :)
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4683384
guys, pulled the plenumn off today.. that was fun. found the problem.. rusted steel branch nipple where cooling pipe actually clamps onto. pipes are still all intact. still gonna replace all pipes under plenumn. counted ten or so under there its a maze. also does anyone know what the aluminium thing is that bolts to the underside of the plenumn?? cheers guys
thanks for the handy advice too!!
https://www.sau.com.au/forums/topic/276694-r33-gtr/#findComment-4683810
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
