Im in the market for some new rims...at the moment i have stock 18s on and what i know is:
If i want another set of 18s without hassles, i need the rim to be 18 x 8, 5 x 114.3 bolt pattern, with offsets of +30mm.
But what if i want 19s to fill the gap in my arches a bit? What size rim do i need without having to get into buying spacers and doing coilovers and all that rubbish that costs extra? Can my current yokohama tyres that i bought recently be stretched over a 19 inch rim without too many problems?
I dont want to lower the car any more (which isnt much at all) because it barely gets over those cement parking blocks around brisbane and at work.
https://www.sau.com.au/forums/topic/276985-question-about-rim-sizes/
  • Replies 81
Posted Images
oh my oh my... rule # 1 - never stretch a tyre into different size rims... you'll break the bead around the tyre rim and it'll just a matter of seconds before the tyre sidewall gets rip apart... mind you that V35 is a relatively heavy car - around 1700kg - they will put more stress to tyre than a 900kg Toyota Starlet. so play it safe....
well if you know your 18" offset, PCD etc, just find a set of 19" with the similar spec in terms of width & offset. anything around 1 inch variance or around 5-10mm offset variance to the stock one might fit. rear is wider so they're easier to fit more aggressive offset at the back than front, as the front you need to find as close possible as to stock so when you turn your tyre don't rub the inner guard, and shave off the corner of your tyre, or causing dented guard.
if you don't lower your car pretty much anything would fit...
here's 19x8.5+30 & 19x9.5+25 look on my car...
V35 are huge car, and even 19" looks small on it. But going 20" or over means you get hardly any sidewall protection over potholes, and will likely be bending the rims if you're not tip-toe-ing around avoiding potholes while driving...
Firstly do you have a coupe or sedan? They are both very different when it comes to what size and offsets will fit.
Secondly you will not reduce fender gap by getting bigger wheels. Bigger wheels require a lower profile tyre to maintain the rolling diameter. Lowering is the only way you will effectively reduce this gap.
I've got a coupe but i dont like the gap - i guess i'll stick with 18s though and see how it turns out...
thanks for the info rs73, i guess i wont be trying to stretch them then. I'll stick with my yokohama's on 18s, new rims will still look 10 times better...i like your ride height and your rims look nice.
Edited by Eldubb
what tyre profile are you running currently? You shouldn't be that low and scraping on stuff with stock suspension? If your tyre profiles are currently wrong, that might be the cause. I had this problem once when I first got mine, it was scraping on the slightest hump. Dealer had put incorrect/lower profile tyres on. Corrected this with new tyres and problem solved.
I think the profile is fine...running 225/40/18 on front and 245/40/18 on back.
Just the front lip always barely scrapes over the cement blocks by 1mm, literally. There's a picture of my car under the detailing posts but doesnt show too well the right height i think.
http://www.skylinesaustralia.com/forums/V3...ed-t274285.html
Edited by Eldubb
there is your problem, you are supposed to run 225/45 and 245/45 in 18s. This is the closest to factory OD and is what the 350zs run on with oem wheels. Put those numbers in a tire calculator and you will see how much difference it mAkes to closing that wheel gap and also increasing your ride height.
Yes. On 225/45 & 225/40, the sidewall difference is 5% of 225mm = 1.125cm
On 245/45 & 245/40, the sidewall difference will be 1.225cm
that would raise your ride height by that much. that's probably just what you need to clear gutter and sidewalk, driveways etc.
Will it REALLY make that much of a difference?
Yes it will. Your speedo will be out of whack as a result and also in QLD, its illegal to go over +/- 15mm your overall rolling diameter. Keep that in mind.
The profile you are currently running will suit 32,33,34 as they have a smaller OD from factory.
Thanks for the info lads.
Danny - i meant i just replaced my 2 fronts for $400 each for 225/40/18. yoko's arent cheap are they :laugh:
Looks like i've be getting a whole new wheel+rim package. Shame.
Eldubb - before you go changing your wheels and tyres let me know as I will be selling both my Volk and SSR SP1 very shortly.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
