you should have a setting on your camera that takes photos in succession at different exposures try that maybe next time so u dont have to press the triger and move the camera?
my photos can be found here... http://www.flickr.com/photos/mkphotographyperth/
but go to the photography stuff (photoshoots)
heaps of the pics on there are just muck around ones and party, any advice wud be great
  • Replies 134
Posted Images
Yeah AEB, The 5D2 only brackets 3 photos though :D
Hey guys, some amazing shots here!
I'm pretty amateur at photography but thought I'd share a few I took of my car last weekend. Just click to view larger.
The first three pictures are HDR.
Any tips/feedback would be good so I can try to improve :teehee:
Also, while I'm here.. can anyone point me in the right direction if there is a thread where people have listed good locations for taking photos of their cars? I'm keen to find some more nice backdrops to head out at night for shots.
Thanks!
Edited by UnCo
...any advice wud be great
lighting in almost all of those are horrible IMO - my advice would be to try the same thing during the day - would look 100 times better :)
edit: i was looking at "Team Fusion Shoot part 2" - lighting in the Photoshoots ones are heaps better
looking to upgrade my camera body. i've got a price at $1600 for a 50D body only. good deal? with the standard lens (17-55 3.5-something) its $2175
I would also suggest a 40D over the 50D !!! So much better value for the cash....... Think you can get 40D now for around 1k..
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
