My car is not a vQ25 that ain't even my engine type
I think you'll find it's a VQ25DD (the direct injected variant of the VQ25). Still doesn't make it OBD2 compliant. Based on what my local Nissan dealer told me you can use Consult 2 to gain most information (that's what they used on my VQ25DD) and Consult 3 is better.
Have anyone ever experience a p0100 on a Nissan skyline v35 250gt what is that
Are you back on the "cheap stuff" again? Scotty nm35, a well respected member here answered your same question back up there on posting #204. It refers to a faulty AFM.
If you have no idea about fault codes, or google searching fault codes, or repairing faults, there are places you can take your car where they know how to fix it, where there are men willing to get their hands dirty to save you doing the hard work... ;)
With no location listed I can't help you find one of these specialists spector. Sorry.
Hi everyone,
I have a 2003 V35 GT300 and I would like to find more info on the EGR block off mod. I tried to search the forum but came up empty...
Also I did the throttle plate clean and I got the check eng. light on performed a ECU reset and the light went off but... when I start up the engine it revs somewhat high to about 1500 RPM for a second or two and then settles would that be normal? I have not noticed that before the clean.
Any help would be greatly appreciated.
Thanks
Edited by pula loca
probably needs an idle air volume re-learn.. assuming the VQ30 has this opiton like the VQ35 does.
How do I do that as I don't have the "check engine" light on?
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock. 1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that the accelerator pedal is fully released, then turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Realistically the idle relearn needs to be done using the consult3, the manual method is hit and miss. It also won't work if you have an engine code up in most cases.
Try it out, if it works you will hear the engine rev to over 2k, then slowly drop to 650 revs. There are other procedures that need to be done before the relearn though, they need to be done in order preferably.
True.. it can be difficult to do with the manual mode. I managed to do it on my VQ35 with a non-functioning CEL.. which added to the challenge.. took me about 20 tries to get it.
You need to do the throttle pedal position learn and the throttle closed position learn first, but they are fairly simple in comparison. It will also only work with an engine temperature within a certain range too.
In the VQ35, rpm peaked up to about 1,200rpm, then dipped to about 450rpm, and settled out at 650.
I was also forced to do the re-learn after high idle problems, post throttle body clean.
Never seen one for under $200 work on v35s
Agreed. if the 250 and 300 aren't OBDII compatable, this isn't likely to work. You will need a real consult2 device or a good clone.
You would have more luck with the VQ35 ECU though.. I have the Blatz cable with nissandatascan, and it lets me do this procedure.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
