actually was doing some test's on the free way last night
if i boot it it will stick @ 4.5 - 5k rpm.
if i ease it into the throttle it will go all the way to 8k without any problems at all..
im thinking fuel pump?
im thinking your coil packs are arching out.
is it a backfire or a boost miss?
backfire is where the engine has two much fuel put into it and it expels it in one burst out your exhaust.
could be caused by:
1. bad fuel
2. shit in the bottom of your tank if you had low amount of petrol
3. running too rich
but im leaning more towards checking your coil packs
I'm having the exact same trouble on my 33 gtst at the same revs, 3inch exhaust is the only mod. Replaced sparks with new standard coppers which seemed to clean it up a bit but soon after the problem was back, most of the time it's worse when the car has warmed up. Been thinking about getting some of those hks iridium plugs that can withstand more heat but at 19 bucks each it would be nice to know before hand if it's gonna help. Maybe check the gaps on your current plugs to make sure they haven't blown out and are in ok condition?
It's sort of a rapid "pop pop pop pop" coming from the exhaust like unburnt fuel is being dropped in to it, engine hesitates badly which causes the whole car to shake around a bit.
yeah, one thing to do would be to get a mate to drive from behind in your case and watch while it happens for smoke out the exhaust.
in your case but nicrwks, yours sound more along the lines of a boost missfire.
couple of things:
1: what rpm is this happening at?
2: what fuel is in your car?
3: how much boost you running?
couple of things:
1. Starts at 4.5-5k rpm right through to redline
2. bp ultimate
3. 7psi (no 2 stage)
Current sparks are NGK BKR6E
Alexxs: do you get the same popping sound around this rpm?
Edited by nicr4wks
yeah my issues start at about 5k rpm, its not a boost leak, ive checked that out..
im going to replace the fuel pump tomorrow, (tried today and fuel tank as full DURRR WHU?!?! im a retard lol)
and doing sparkies tomorrow along with taping up the coil packs i guess.
car hasn't been boosted stock 7psi
its frustrating sigh :teehee:
*edit*
im about 1/3 of my way through a tank of 98 with some injectors clears in it.
always run 98, vpower or bp ultimate.
Edited by Alexxs
Sorry for hijacking the thread. I've got back firing issues as well.
Mods:
Yellow Jacket Coil Packs
Plugs gapped to 0.8mm
3inch turbo back exhaust
Pod Filter
FMIC
I'm also still running the standard factory solenoid. Somehow when I'm flooring the throttle, I get up to 10-11psi of boost.
Anwyay, when I'm in 1st or 2nd gear and I back of the throttle at about 5000-6000rpm, I can hear back firing. There's no smoke coming from the exhaust.
Can anyone diagonse this?
Mods:
Pod Filter
FMIC
if it only happens when u back off the throttle id say ur running rich. really rich or ur fuel pump / injectors need a clean / replace.
hey everyone.. ive got a bit of a smiler problem but 10 times worse to the point that its not drivable :laugh:
about 3 days ago had my car parked outside a mates house.. and it was hell stormy weather.. anywayz i went to start the car it started then stalled.. so then i tried again this time it stayed on. but then as i went to drive off it stalled again. i noticed that every time i pressed the accelerator heaps of black smoke came out the exhaust which i know means its running rich.. but this wasnt just the usual lil bit of black smoke it was to the point where u could smell fuel and yor eyes would burn.. this obviously means that theres heaps of fuel that isnt getting burnt.
anyways i managed to get the car home and i took the coil packs out to look at them and there was water where the spark plugs are (decent amount). i drained it all out.. dryed the coils and put it back together started the car and its still doing the same thing. then i took the spark plugs out them and found that 3 of them were wet from the fuel.
this is obviously an ignition problem any ideas how i can narrow it down to wot part of the ingition system is stuffed? whats the best way to check the coils and the lil modual that sits on top of the plastic cover on at the back end of the engine etc??
help please!!!!!
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
