Hi everyone.
I smashed my front bar at the last drift day and I need one to get allign the front again.
I would like to buy a genuine GTR bar so if you have one let me know.
Otherwise does someone have one that I could borrow for a few weeks? Any type of R32 front bar will do.
I'm in Doncaster East.
Thanks guys
Russ
0421332860
https://www.sau.com.au/forums/topic/278402-r32-front-bar/
  • 1 month later...
Hey Russ I have my old front bar sitting at home that you're more than welcome to use if you need it. Only damage is one of the mounting points snapped off when guttered the bar that has been temporarily fixed and holds well.
It's not quite black but if you want it, it's yours.
https://www.sau.com.au/forums/topic/278402-r32-front-bar/#findComment-4776676
i got a spare aftermarket one if your interested.
some sort of drift style one abit dirty but would do the job.
30bucks =]
I think I'm all sorted. thanks man.
Although still looking for a genuine GTR one for a reasonable price.
https://www.sau.com.au/forums/topic/278402-r32-front-bar/#findComment-4780553
hey russ
i dont think u can use a genuine GTR bumper on a gtst, coz of the gtr's flared guards. i know 100% u cant for r33's so id imagine the same for r32..cheers
i think he used to run a GTR bar before he crashed it...
https://www.sau.com.au/forums/topic/278402-r32-front-bar/#findComment-4795414
Look at my avatar :) (gtr bar, standard guards)
But i wouldnt mind GTR guards and bonnet when I sell the stagea and get new rims, plus the weight saving of the bonnet.
Edited by RB_Ryan
https://www.sau.com.au/forums/topic/278402-r32-front-bar/#findComment-4795420
there's one on ebay in white emacc condition for $700 but lol
edit: $800 lol here is a link
i want it
http://cgi.ebay.com.au/JDM-Genuine-NISSAN-...id=p3286.c0.m14
white r32 gtr front bar link to ebay item
https://www.sau.com.au/forums/topic/278402-r32-front-bar/#findComment-4799589
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
