Hi all
I just bought an R32 gtst. The BOV is stock and it makes a flutter noise when I change gears.
Today I was taking the plumbing off to get access for the coil packs and noticed that when I took off the stock BOV connection to the intake plenum (<> shaped with 2 bolts holding it together), the gasket was there, but the shonky guys who owned it before me had made a plate from a 'Mother' drink can to close off the pipe, essentially blocking the plumb back.
When I took it for a drive after I removed their dodgy 'fix', when it was under boost and gears were changed it made a really bad hissing noise, something was definately wrong.
Anyone know of the problem and how to fix it. I have put the 'Mother' can mod back in place because the car was undrivable otherwise, was not handling boost at all.
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/
Two things.
First, the can gasket was put there to block the bypass valve intentionally. A lot of the younger generation do this for what they refer to as a dose (the flutter) noise. This is potentially harmful and not a good thing to do.
Secondly, by removing the can and you are using a pod filter and you hear a whoosh noise when you change gears, that's just the bypass valve doing it's job to recirculate the pressurised intake charge to the front of the turbo. This is normal if running a pod. If you use a stock filter box, the noise will be less predominate.
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4705624
Two things.
maybe the gasket has broken down because it wasn't a normal air noise, it was a very loud hiss. the stock BOV is just a very simple unit isn't it ? its just plumbing back into the plenum, theres nothing else I need to be looking at besides a new gasket ?
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4705763
Was it a constant hiss under boost, or only during gear change?
The stock bypass valve recirculates from the intake manifold to the inducer in the front of the turbo.
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4705828
only during gear change, i only drove it about 50 metres before i went back and replaced the mother can mod. not so much of a hiss more of a roar, definately not like it was supposed to sounds like, the factory quiet standard
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4707580
If it's only hissing during gear change then it's right.
The ultimate question still hasn't been answered - Do you run a pod filter???????
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4707701
yeah mate its got a pod filter on it.
The hiss noise you are hearing on gear change is the bypass valve recirculating the air from the intake manifold to the front of the turbo. Have a look at the valve and you'll see a black steel tube running to the inducer.
You are hearing the hiss coming through the pod filter. If you had the stock airbox in place it would sound like a mild hiss/squeak.
There's nothing to worry about man, you can put the stock bypass valve back in place without any problem.
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4709175
  • 1 month later...
yeah, i have a stock bov on my 32 and a pod filter and the woosh/hiss noise is very loud, even tho its plumb back, everyone who goes in it thinks its got an aftermarket one coz its so loud lol.
how bad is it to block it off for shits n giggle for some flutter?
it would be good if it was adjustable so at like say anything under 4 psi boost it woudlnt open and it would flutter but anything more and it would open, that way u could have flutter without the risk of to much damage to your turbo?
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4796787
On my R33 I have a pod with stock BOV... very loud hiss when I'm nearing gear change time! hahahaha but yeah, you can block it off for flutters... or squash the stock one down a bit so it tightens it up a bit, for less hissing, and even some flutter.
Alex - a squashed stock bov would do exactly what you described. I didn't want to risk mine, so I bought one off a fellow SAU-er. Ask at wreckers if they have a spare stock one sitting around, but I doubt it. I couldn't find a stock R33 bov at any wrecker near me.
The other options is obviously an aftermarket BOV, tighten it so that it only dumps once the pressure is up a bit higher.
Edited by mosquitocoils
https://www.sau.com.au/forums/topic/278485-r32-stock-bov/#findComment-4797708
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
