Hey guys,
Well i recently bought a 34 GTT, it was factory optioned with 8 speakers.
My issue is that the 2 rear speakers over the top of the boot..(subwoofers?) have been removed. I just have the covers sitting there with a female plug connection going to one of the speaker covers.
Anyway, I don't really know much about car audio/speakers. And I just need to know what was there originally so I can replace them.
Cheers,
Rohan.
https://www.sau.com.au/forums/topic/278526-r34-rear-speakers/
Oh ok, well I'd be happy with stock speakers to be honest, hopefully I can find some that fit.
I am actually really happy with the sound quality. And I'll be honest and say I didn't notice the missing speakers for a bout a week until I started to wonder why I couldn't hear anything coming from the back. :thumbsup:
One other thing, The one female plug adaptor, will that service both speakers?
Sorry for the noob questions, never messed about with car audio before.
Hey Jack, I just had a quick look and found the other connection for the other speaker fitting.
One has a 4 pin plug like ( .... ) the other side has a 10 pin plug like ( :::.:: ) or something like that.
well the 10 pin plug is defenantly not the one you want.did you unplug that from anything or was it just hanging under the parcel shelf? there is a computer mounted under the rear shelf which it should be pluged into from memory, check the little box thats mounted under the shelf and see if it has anything pluged into the plug onthe side of it.
Are you able to take a picture of the 4 pin plug for me?
Yeah mate I will.
I'll take a pic of both and report back tomorrow afternoon :thumbsup:
Cheers for the help.
No probs man.
off the top of my head the rear speaker wires should be
Rear Left neg = Black with pink stripe
Rear Left pos = Orange
Rear Right neg = Grey with red stripe
Rear Right pos = Grey
not 100% tho,its too late at night to think lol.
cant really tell where the 4 pin plug is from in then pics.the 10 pin i think is from the computer mounted under the parcel shelf.have a check on the side of that and see if there is anything pluged into it. on the 4 pin plug cross check the wire colours of that to the wire colours i posted abit further up and see if they match up.if they do then thats ya man if not then have a hunt around under the parcel self and see if you can locate them, they may have been tucked up under the parcel shelf (inbetween the steel part and the plastic part you actually remove).
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
