Hi All,
the other day when i went to get some new tyres put on (Kumho KU31) the guy was about to do a wheel alignment and was checking the brakes and the suspension parts and he advised the front lower control arm bush needs to be replaced.
questions
1. has anyone else experienced this?
2. if so where have you taken to get fixed and how much should i be expecting to pay.
Regards
https://www.sau.com.au/forums/topic/278601-front-suspension-bushes/
Is it the lower control arms or the lower compression rods.
I had to do the compression rods in my stagea and that was $650 as i had to buy new rods from Nissan. If its the lower control arm inner bushes then you can buy Noltec bushes from whiteline for the 350Z these are the same as the V35's & M35's
Pages_from_WHITELINE_PLUS_CHASSIS_CONTROL_CATALOGUE_1_.pdf
I just had the RACQ report on a 350GT that Im looking at come back with split inside lower controll arm bushes as well. Any ideas on cost to repair? I want to try to get a few more dollars of the cars price.
Just got a quote from a workshop on the Gold Coast: $55 for the bushings, 2-3 hours work for both sides.
Edited by RedDragonAus
Hey red dragon...i called nissan and asked about the 350z bushes but got told that they only sell the whole control arm including bushes ($295each) for parts only. need to go back to them with the vin # for the V to see what they can do for a V35 specific part ill let you know once i have done that.
i got quoted by tyrepower $250 each side for replacing the bushes only with aftermarket variants, but not sure what brand they would use.
i'm going to call around a bit more and see what else i can find.
  • 2 months later...
Hey guys my rear shock bush is tearing, thanks to the whiteline list I've found the bush. Now I'm wondering if they can be replaced on the car or if I'm going to have to take the rear axel off and get them bench pressed. Does anyone know someone who can do this quick and painlessly?
  • 7 years later...
I bought this bad boys 1-2 months ago. The mechanic told me it's genuine OEM when he received the parts from me. I paid 200$ for labour.
http://www.ebay.com.au/itm/252153035501?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Hope that helps.
you can get genuine compression rod bushings, but not LCA bushings.. those in the link will likely be febest bushes.. probably ok, but not genuine by any means.
EDIT-.. actually with a part number like NAB-089, I guarantee they will be febest bushes.
Edited by sonicii
  • Like 1
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
