Already running a big brake kit, 324mm curved vein rotors, modified gtst calipers, ferodo 2500 pads, good set up and works well,
just have a chance to buy some brembos and was wondering what was a fair price.
Pardon my ignorance, what is a g4s?, dumb boat owner here don't forget. :thumbsup:
way too high....people ask (and get) up to 1500 for used calipers. no rebuilt seals. no discs ($800). no brake lines ($500). no pads($200)
just by g4s instead for about 2k in similar size 330
https://www.sau.com.au/forums/topic/278752-going-rate/#findComment-4710406
indeed, there have been some bad reviews of the shocks
before you dismiss the g4/d2 brakes you should check out the posts from people who have actually used them though, they are excellent. I have bought 3 sets now, I run them on Kel's 350z, my stagea, and the sports sedan gtr :blink: people like tacker have used them even more extensively without problems.
https://www.sau.com.au/forums/topic/278752-going-rate/#findComment-4716730
