Hi, my 2003 V35 GT8 Bose 6 stacker CD player is broken and displaying the F0 error. I am using the RCA ins in the TV module to play music from my iPod. When I start my car the CD player tries to eject each of the six CDs in the CD player - so I get a ticking type noise for say 10 seconds every time I turn the car on; then an beep as if to tell me it didn't work.
Is there a way that does not involve me removing the unit from the car to make the CD player forget about trying to load CDs?
Thanks, Ben.
  • 1 month later...
The stacker in my sedan gave in to the "ERROR F0" yesterday aswell... :(
The sound it makes is murderous! Im not going to try and fix the stacker. I have a Chris Rodgers under the seat dvd special, and im in Perth which limits my options... But i do want to put and end to the sound also.
Any DIY's on how to unplug the stacker??
I have the "Instrument Panel Assembly" service manual, but any help would be appreciated.
I was thinking maybe a sledge hammer would do the trick :)
for all those keen, my 350GT-8 sedan bose cd player (6 disc), MD 6 disk stacker, panasonic 7" lcd screen, panasonic satnav (japanese) with 4GB hard drive and SD card slot, factory reverse cam is up for grabs...when I do my full stereo install, i'll post it up..stay tuned!!!
my centre console fascia with the dual climate control and A/C module is likely to go up for sale also...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
