hey guys girls and those who fit into both categories....
just wona no how i tell if my new leather seats have heaters in them... the dude b4 me got them from jap jap land... pics of the base/cords as follow :blink: cheers.
the one with the blue stuff is the drivers side.. but the passenger doesnt have it :S weird...
do the heaters have there own plug or tap into power threw the one plug. cheers :O
Edited by chef_stagea
yeah, there is a seperate plug for heated seats (the switch for them is in in the console).
s1 seats are electric movement/no heaters and have a 2 pin plug only
:blink: what eva! whats the blue and grey wiring on the drivers one for then :S
:P what eva! whats the blue and grey wiring on the drivers one for then :S
I had a look at mine and I definately have 2-off 4 pin plugs + 2 other plugs under my driver's seat and at least 1-off 4 pin plug under the passenger seat .
I have the blue plug as well under the drivers seat which seems to be connected after the 4 pin plug.
The Series 2 ones have electric functions for the following;
DRIVERS SIDE
slide front back
recliner up down backrest
seat tilt
PASSENGER SIDE
slide front back
I disconnected the 4 pin plug and had no electric seats but my heaters still worked! So all I can say from this is that the blue plug you say may be related to a function that the passenger seat does not have (SEAT TILT?).
To tell if they have heaters I would be looking at the back of the seat and look to see if you have small black flexible electric coming out of the back of the seat and going into the inside of the backrest of the seat. If you were sitting in the back seat of the car and looking at the back of the front seats you would see the conduits where they come out from the seat to the inside of the backrest.
Just by looking at your photos, looks to me like you may have electric seats but maybe (series 1?) with limited functions (2 pin plugs). To confirm this post photos of each side of the seats where the controls are for the electrics- there should be some diagrams also. This will tell you what can be electrified and what can not.
Hope this helps.
yeah my seats do as you described....
i couldnt see this condute u were talking about if i sat in the rear. had a good feal around where the back rest hits the seat and didnt find ne thing. how ever i did find this random plug. the plug on the seat, goes into one in the car. this didnt give me movement in my seats... is this 4 pin plug going to? i dont have anywhere to plug it into tho :S
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
