I'll go for 265. Anything more than that will be quite horrible to drive I reckon (not much experience with tyres but the current 285 all round are are to steer when you hit a bump/pot-hole on the road). The other thing would probably be to get really good tyres (since your life depends on the 4wheels).
My rule of thumb is to use the width of the rim + 10%.
So 9.5" = 241 mm + 10% = 265 mm
Then one size smaller is OK (ie; 255 mm) or one size larger (ie; 275 mm)
Now if only the tyre manufacturers would make their tyres the same size as they label them. For example I have a Yokohama 235 that is 239 mm wide and a 245 that is 242 mm wide. Yep, 10 mm larger on the sidewall is only really 3 mm according to Yokohama.:P
Cheers
Gary
thank you for all replies guys , i have went out and got 245 and see how that goes.
i was thinking between a 275 and 255, but imo i might not be able to fit 275 as the 265 i had previously sits close to suspension.
will see how i go with my 245 , so far traction is good and handles nice. i gotten a cheaper brand as my camber chews the tyres out but im in process of deciding to fix the camber a little then once that's sorted i can get some proper tyres.
will take some pics soon of 245 on 9.5 rim
btw how long does it take so that protective coat comes off tyres so they can be pushed harder.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
