Hi guys
ive had a search around the forum but i cant really find the answer to my problems
my second cylinder aint firing on my rb20det :banana: i know this bcoz when i go along and unplug each coilpack, the second one is the only one which doesnt change the cars idling rate
so i started by swappin all my plugs around, and shes still missin on that 2nd cylinder
swapped coilpacks over, still missin
now the only other thing im guessing is whether the injector on that cylinder may be blocked, so i ran some injector cleaner through my car, didnt work
tired another brand of injector cleaner, didnt work
so im hoping its that injector which is fluffed, my question IS - what else could it be if its not the injector?
also, if im to swap to different injectors, which ones are the best to go with?
im kinda leaning towards gtr's with a resistor pack, but i dunno whether more cc's are better or high and low impedence is better
i am lost, sorry moderators if there is a thread similar, i wasnt able to find one
im hoping im not up for big dollars to fix something internal... >_>
Edited by fourdoorlove
https://www.sau.com.au/forums/topic/279493-why-is-my-rb-spittin/
ditto.
i had the same problem , turned out to be the loom plug that goes onto the coil....\
look around for any cracks.....take it apart and rewire it if u have too...
shouldnt be anything sinister...
GL
Do you have power at the injector plug? I think it's called a noid light.... plugs onto the injector plug (take it off the injector first) and the light pulses with injector operation....kinda crappy explanation, but yeah....
Take your plug out of the cylinder, start the car, see if it sparks......
if it sparks u know its not ur loom , coil , plug.
put a test light to ur injector plug, start car if the light comes on when the injector fires its good.
(ps dont take ur injector plug off ur injector. just push the test light into the back of the plug.)
the only other thing i can think off is that the fpr is f**ked , its running too low a fuel pressure... and ur high idle is from a lean mixture....
can you adjust ur idle on ur aac?????
check ur fuel pressure, maybe try another reg.
Maybe a big air leak some where????
GL
ill try the test light theory..
ive just installed a new fpr and its running at around 70-75psi
it was still doing the same thing on the standard fpr, so i dnt think its that
a mechanic friend of mine said its most likely the injector that is not working or is blocked, but ive ran two diff types of injector cleaner through it and still no result
if u think its the injector just swap it with another cylinder....
pull cyl 2 and 3 and put 2 into 3 and vice versa... that will tell u if the injector is f*ked
i pulled the coil and plug out and ran an earth wire to the body from the plug and pluged everthing together.....
turn it ova while some1 whatches the spark... if it sparks.. its all good... if it doesnt ,,,, well thats that....
GL
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
