Hi all,
Selling my Volks as I have upgraded to 19s. I would really like to see this on another sedan if possible. Offsets would suit coupes as well but won't look as agressive as compared to on a Sedan.
18x8 +33
18x9 +31
Tires are 225/45 Sumitomo HTR ZIII 70%; 245/45 50% $1100 when new
Tyre review here: http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=93
Come with additional CF Rays wheel caps as well which cost me an additional $200
Selling the lot for $2800 pick up Southside Brisbane. If you are planning to stick this on your sedan, you will need to have been lowered at least 1" and rolled your rear guards.
Will also suit R32,33,34.
Wheels are flawless and the closest you will get to brand new!
PM for more info.
https://www.sau.com.au/forums/topic/279581-fs-volk-gts-top-secret-gold/
  • 4 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
Boxing day sale reduced to $2300!
Perfect for lowered V Sedans, R32,33,34 and most Nissans!
What you get:
Wheels x 4 in immaculate condition
Sumitomo HTR ZIII performance tires with plenty of thred left
Rays CF Wheel caps
* If purchased at $2300 will thrown in a set of used Blue rays duralumin lug nuts as well!
Treat your car to a set of these for the New Year! :D
  • 5 weeks later...
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
