i have one 400r kit for a r33
give to me as payment for a part that i sold. so its for sale
kit consists of
front
side
rear bar
front grill
and eylids
unpainted but ready to go
same as one below
you have to paint it which mean probably 600
dont really want to sepparate
asking 900
pete 0409226626 sydney
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/
  • Replies 60
fatz,
i might be keen if you can hold off for a little while...
i am paying insurance this month as well as getting a S-AFC, so i'd be hella keen in a month or two.
if not, then thats cool.
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/#findComment-49812
kit is new *** sik as lol
Gerds - im talking to a few people to find out how much it would be to paint tha bastard... looks like being 600 at a place on paramata road. that make 1500 and *** me for 500 ill fit the bastard cant be that hard couple of self tappers and a few hours(never done it so thats a bit tounge in cheek).
prank- if its still there when your ready no dramas
jimbo- fresh out of the molds
front bar
side skirts
rear bar
front grill
and eylids
for 300 more can get a gtr wing if you like but i doubt it
pete
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/#findComment-50249
place on para cant remeber its name but when i worked for big boyz toys they sent a few car there so i know the guy now.
he did a repair and paint blue metalic flake front and side skirts for 600 and that was tops so im sure standard paint would be cheaper
can and will find out the name on the weekend but its opposit bp and where the old hooters was
prank- yup they r **** hot fill the guards nicely ill take a photo in a minute and post it up. stake knifes r dodgy but there yours from a drunken night at blackstump stole a few for kicks
body kit pphotos will be up tommorow night depending of drunkeness
r
pete
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/#findComment-50773
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
