in NSW your front windows can't be less than 35%.
my R34 came with factory privacy glass (rear windshield and quarters) which looks VERY dark with the dark stock interior, probably 20-25% but I believe it's legal as its a factory option and the tint is built into the glass.
I just had my front windows tinted to 20% and I thought it wouldn't be dark enough ...looks illegal ie. VERY dark but I haven't had any issues with the law YET... Visibility at night in dark streets is pretty crap and I often wind my window down. But it LOOKS great .. Another thing, I do have creme colour interior now and from the outside you can barely see anything inside. So 20% with the stock dark interior covers would look pitch black. If you're worried, stick to 35%.
It's only $100 to redo the front windows if I ever get busted so it's not that big a deal to me.
As per the RTA (NSW) rule, no windows on a passenger vehicle can be less than 35% tint (which means 35% of the light makes it through the tint).
There are good reasons for it, the main one being visibility.
Please don't advise someone in another state of your own beliefs of the NSW rules as it may mislead them.
This is the rules from Vicroads (which I assume your car will come under since you are from Geelong.
It took me 5mins to find with a simple google search and I have no experience with the vic roads rules or website.
My bad, tad lazy on my behalf..
so the front ahs to be lighter :ninja: hmmm
Mine had slight factory tint.. so tinting will seem even darker.. :)?
lol he's already been told to check the rules for his state, I only shared some information based on personal experience. EDIT: oh and it looks like Vic rules are the SAME ie. 35% so NYER.
On a side note, you drive a friggin Golf you shouldn't be advising anyone on anything vehicle related :)
Edited by Delta Force
The film used in tinting reduces light that passes through the film. So, of course it is going to be darker, just as the night is darker than the day due to reduced light.
On a side note, you drive a friggin Golf you shouldn't be advising anyone on anything vehicle related :ninja:
Your personal experience is irrelevant due to it being from another state. That's why I said
In Victoria (going from those rules on vic roads site) the front cannot be 35%
What car I drive, clearly has no bearing on the legalities in any state in regards to window tinting or otherwise, nor in the abilities of another forum member in searching for an answer to their question in the right place. FYI, it has 35% tint all round (except the front windscreen, as per NSW RTA rules)
Where are you getting that info? The document you yourself linked to clearly states 35% for windows.
As for the golf comment, chill it was a joke :)
As for the golf comment, chill it was a joke :ninja:
In reference to the above quote the front has to let 70% light through. I.e. 35% tint would not comply
A transmission level of 70% is the requirement on drivers / passenger windows in South Australia (but you can have 35% behind the driver) - SA Transport - Tint Legalities.
So yeah, as you can see this stuff really is very state-based. My reading of that page from Vic suggests that 35% may be legal, but it's recommended to be 70% transmittance.
also remember that different tinters will have their own shades and percentages
i.e. 20% of one tinter may be darker then another tinters 20%
best is to get them show you some samples and you can decide from there.
now you're just talking out of your ass ..read your own damn link.
35% is LEGAL. 70% is 'DESIRABLE' ie. irrelevant as it's just some paper pushers personal opinion or so it would seem.
In Queensland its 35% transmittance too...
2008 Mods guide
http://www.transport.qld.gov.au/resources/...r_vehicles2.pdf
Just remember with front tint you can't have the tint lower than the top swing part of the arcs of your wiper blades....
-----NSW------
http://www.rta.nsw.gov.au/registration/dow.../vsi03_rev3.pdf
as of 2003 guide
in NSW the tinting on front window can be no lower than 10% of the windscreen, this tint is max 25% transmittance
All other windows can be up to 35% transmittance
-----VIC------
http://www.vicroads.vic.gov.au/NR/rdonlyre...E621/0/VSI2.pdf
In VIC all windows can be transmittance 35% except windscreen which is 30%
in the section there is goes into details of loopholes... the 70% is a safety suggestion... like not smoking....
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
