I just had a blitz turbo timer installed and the instructions are in japanese, this would be alright if I could read it. can someone tell me which mode is fully auto. it is a blue box with silver & it has BLITZ FATT on the box. I think I found the mode but you still have to set some sort of time or it always stays on 0. I hammered my car and it wanted 2 secs
I think it is the model just before this one, it is silvier and when the car is counting down it flashes red then blue in the backlights
http://www.prostreetonline.com/pso/pages/d...roductsku=14354
it only has 3 buttons on the front, you move between modes by pushing power. it has things like 0-400m, speed, a speed warning.
https://www.sau.com.au/forums/topic/28016-blitz-turbo-timers/
I got the DTT
- The left most button sets the display and also function mode eg. set it to a fixed time, auto timer, boost gauge display etc etc
- When u set the mode to auto timer, u can press one of the 2 buttons on the right to set the mode of the auto timer:
either Boost - Low, Med, Hi
OR Time - Low, Med, Hi
Also, when u press the other of the 2 buttons it should set the minimum amount of time for the auto timer (i set it at 50 sec)
Hope it helps. I just have the jap manual, but I was fiddling for a while and worked it out. I think you need to fix your sensor if you are getting half the speed display on the FATT. Good luck
I dont know about the Blitz timers but the HKS timers with speed and tacho inputs have a calibration setting. As in you press a button then once you reach 40kph you press it again which teaches the timer the how to read the speed signals. Id say if the speed on the timer is going up with the speed of the cluster even if its reading wrong it should be wired correctly.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
