For sale:
1984 RMR30 Nissan Skyline Ti Liftback
Item Condition:
Excellent
Price and price conditions:
Looking to sell ASAP, will take $1500 drive away (slightly negotiable)
Rego runs out very soon, will sell with 12 months VIC rego for extra $500 (along with a staturary declaration on your behalf)
$1500 neg as is
$2000 neg with 12 months rego
$3000 neg with a mountain of spares and turbo conversion
Extra Info:
One of the early best 1980's luxury cruisers/sports hatch
Cared for & maintained by enthusiast for last 3 years.
Fully optioned, power steering, electric windows, electric mirrors, air con.
3 speed Automatic with selectable Overdrive ( as in the later model R31 skyline)
4 wheel disk brakes
Alloy rims with plenty of tread
Smooth running 109kW L24e EFI 6 Cyl (2400cc, mid capacity) fuel injected version of the classic datsun 240z engine. (great torque and reliability)
N47 head (8.7:1 compression)
3.9 ratio R180 independant rear
R31 front sway bar (4mm thicker than original)
143,000km (will get exact numbers soon)
16x7 powdercoated black alloy rims, 225s wide all round (dunlop bathurst up front, bridgestoners at back)
Regularly serviced, all filters and oil recently changed, radiator flushed, all fluids topped up. new brake fluid/brakes bled and wiper blades.
Any major work completed by Nissco (datsun race/rally workshop) in Bayswater, Melbourne.
Has had professional detail and Victorian RWC within the last 12 months.
Interior is in excellent condition, all switches and buttons work.
Great to drive, kerb weight of 1280kg means easy to get to speed limit on main roads,
great for cruising due to overdrive enabled transmission
Good visibility all round, easy to park & change lanes.
Great turning circle (unlike most cars these days).
No modifications (apart from alloy rims and sway bar), all original factory spec.
Able to view in Canberra, in Mitchell during working hours, or Deakin after hours.
Comes with original genuine Nissan toolkit, and service pack incl nissan filters, & brake pads.
Various spares available upon request.
(like pacemaker extractors or
full turbo conversion,
microtech LT-4 fully mapped and plug in loom& calibrated sensors,
turbo dissy, oil pump, drive shaft
turbosmart dual stage boost cont. and adjuster
bosch 070 new fuel pump
2 3/4 inch madrel bent system,
highflowed T3/T4 & VG20et turbos
HKS BOV, HKS oil catch can
JDM TURBO rocker cover
XR6 intercooler,
Z31/300zx 50th anniversary front seats (extreemly comfy and look great)
270cc injectors... the list goes on,
looking at $1000 for all this)
It is a 25 year old vehicle, has couple chips and marks on the paint work, but all in all it is a very reliable car, heaps of room, easy to service and park.
Would suit first car buyer or nissan / datsun enthusiast, or someone looking to buy a good cruiser that is different from the rest.
Reason for selling is we have decided to become a 1 car operation until we have a house deposit saved up
Contact Details:
Andrew
<removed by mods>
Deakin/Mitchell , Canberra ACT
Delivery & Conditions of Delivery:
Can drive to you, will deliver if within 200km
slightly extra to melbourne/sydney to cover fuel and return trip
Pictures:
Will be uploaded soon.
Just a few currenly on imageshack from 10 months ago
will find link soon
Posts: 44 http://s330.photobucket.com/albums/l435/MR30_SKYLINE/
more to come (uploading heaps now...)
some good ones from this years show & shine on parliament lawns
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
