Hey guys.. couldnt find the tech help section.. so i figured this would be the best spot.. kinda..
I have an R34 GTT, recently i thought my water pump had died on me as i was getting no water flow through the top radiator hose, the top hose would be hot, the bottom hose would be cold.
So i took out the thermostat all together and tried again.. yet again no water flow.. so i got a hose stuck it in the bottom hose, water comes out the top no problem, vica versa still OK.
Swapped the water pump + thermostat on the weekend to an Rb30 item + Nismo thermostat, while at it i swapped my rad hoses to Silicon items aswell.. (mate told me my factory water pump still looked OK, it only had the slightest play in it, blades all ok)
Now by no means am I a mechanic, so i could be missing the most BASIC thing in the world. I've filled it up.. and yet again it seems like no flow. I idle the car for about 10 minutes and you can feel the pressure building in the hoses (as normal.. kinda..) and then the rad cap opens up to let the boiling water out of the overflow hose.. obviously at this point i turn the car off and let it cool down..
PLEEEEASE help me.. so confused and have no idea or reason i can think of as to why its overheating SO easily.
Also, if anyone knows, does ALL the water from the engine HAVE to pass through the turbo water lines, mine look abit small (Apexi turbo swap) and if it has to all go through the turbo i think that could POSSIBLY be the issue..
Edited by illusiVe
Sounds like the Radiator is blocked. Actually, it seems obvious. If you have changed everything bar the radiator and its still doing it...
PS Nismo thermostat is only causing you more harm than good.
radiator seems to hold pressure no problems.. its only when the car is getting damn hot im getting steam outta the overflow hose.. at which point i know its too hot..
if it is the radiator it'd have to be a DAMN tiny hole.. cause i dont see any steam ever coming out of it itself, nor water
i can get water through the radiator no problems with just pouring water in the top pipe, it comes straight out the bottom pipe of the radiator.. imho it also wouldnt explain why i dont get water coming out of my top radiator hose =(
ill still doublecheck + swap the radiator tonite.
Edited by illusiVe
It's not going to be the turbo water lines.
Now what temp are you getting on the cluster? Is it actually moving off half way and towards hot? You might still have a bad radiator. Just because you put water in the top and it comes out the bottom doesn't indicate it's good unfortunately, the core can be flowing poorly and water will still flow out OK. Have you been running coolant in it?
I would remove the radiator and take it to a radiator place to be check and cleaned. Failing that you may need to look at a possible head gasket problem, of which the symtoms can be found on here by searching.
Get the rad properly checked out first but, re-fit it then move on from there.
thanks james.
yeh the temp cluster moves up towards high.. but in my 3 years of owning it until this issue happen'd i had never seen it go past half way. I have always ran coolant in the system, however since the issue im just throwing water in until i can fix these stupid gremlins.
Can you just throw me a basic reason/s as to why it could be headgasket related?.. just cant make sense from it.
after talking to a mate, apparently RB's have a bleed valve somewhere near the intake mani? (plz confirm) which u need to open to get all the air out...
i have no idea where this is or what it looks like (i know what an intake manifold is though!) if anyone knows or can pics me.. would be HUUUUUUGEly appreciated.
  • 4 months later...
old thread but issue continues..
ill check for the second one tomorrow.. going to start from scratch
1)clean out engine water lines, thermostat+housing,waterpump+rad
2)redo thermostat + waterpump, wait for goop to sealup
3)bolt shit back together
4)fill rad with fresh coolant.
5)bleed system + test
anything else i may be missing?
  • 4 weeks later...
mate i got the exact same problem.
tried all the stuff you have....
i just keep a close eye on the temperature and if if gets too hot when im in traffic i just give it some revs to get the water flowing...
pretty lame but im to lazy to figure it out lol
  • 1 month later...
had a water leak at the back of the block, having it fixed and new lines made up.
battery check yours =)
remember stock gauge doesnt go up until its PASSED a safe temperature for awhile..
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
