Hey guys officially decided to get off my ass and properly sell the 34, as my new car will be finished this week.
So need to get this car sold, as its just sitting in the garage and needs to go to a new home.
Located: Gold Coast
For Sale: Yellow, 99 Model R34 Skyline, 5 - Speed Manual.
Some general specs, a lot of others that cant come to mind at the moment.
Full Impulse Bodykit,
Nismo style Carbon Fiber Bonnet
Carbon Boot Lid
Tanabe Type R Coilovers
Hybrid Intercooler
Apexi pod filter
Greddy Turbo Timer
Blitz I-colour Boost Controller
8000k H.I.D's
C-West Carbon Fibre eyelids
Nismo Short Shift kit
Nismo Gear knob
Audio
Pioneer Type R 12inch sub
Pioneer Digital amp (cant remember model name)
Type x DDliner splits, front and back
Pioneer DVD player
DDL DVD screens in both drivers side and passenger side
All original parts will be included with the sale.
KM's are about 140,000 car was used as a daily to get to uni everyday.
Car is always serviced every 5000kms with Motul Oil, drives perfect. Inspections Welcome.
Looking for $20,000- Wheels are not included and some stock wheels will be put on for the sale.
Contact details: 0431 727 830, If you have any questions don't hesitate to ask.
Cheers
Darren
https://www.sau.com.au/forums/topic/280833-yellow-34-gt-t-wont-disappoint/
TO THE GUY COMING TO LOOK AT THE CAR ON SUNDAY (tomorrow) CAN YOU PLEASE CALL ME!!!!!
I lost your number, and i need you to come before 12.00
cheers mate.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
