Thanks.
So what exactly does it do?
Im looking at a motor that doesn't have this, is this bad.
Sorry for the stupid questions.
How much to replace? etc..
it gives spark to your coils, if it don't have this it wont run unless running a really good aftermarket computer that has this built into it.
https://www.sau.com.au/forums/topic/281023-part-on-rb25det-motor/
Found this, it explained a fair bit.
http://www.skylinesaustralia.com/forums/Ig...ule-t13496.html
My mate has a late series 2 skyline and his motor has the holes at the back of the cover where the module is suppose to be.(with brackets etc) he has the wires setup differently going across aswell. My 97 stagea has the unit and Im sure it has a S2 motor in it.
It doesnt seem to be doing much.
Is this ok. Should he go looking for a replacement?
no... I don't think so.
I'm Guessing your stag has an earlier model 33 RB25DET spec engine in it. (96 model?)
Most S1 Stag's have S2 R33 engines in them - which do not have an ignitor module seperate - it is built into the coilpacks.
If he has a series 2 R33 then he doesn;t need one... he should just have the holes
Check FAST for your relative part numbers - or alternatively.. ahve a search for Splitfires.. you will notice that there are different splitfire partcodes for different 33 spec RB25DET's... one for the old model and one for the new.
It doesnt seem to be doing much. What happens if it was removed?
Edited by dirtyrs4
Yeah you are right mines a late 96 and he has a series 1 and should have one.
The reason I ask is when I looked at it after he got it back from a service it looked like it was missing.
There is still part of the support bracket on the module that is just hanging there! Dodgy!
I told him to get back to the mechanics and get it fitted back on properly, maybe somewhere else.
The car seems fine. Would this have done damage in the long run?
umm not really right....if its a S1 motor and the ignitor is missing it will not run at all. So if its runnign (even badly) its not the problem
This is what is missing. And is a R33 S1.
The car starts rough but still runs fine.
But they have done some extra wiring between, I will post a picture.
I suppose a Splitfire super direct ignition system would be of benefit (upgraded coilpacks and module),
but he has been quoted $120 from a wrecker replacement and $215 (genuine) new from;
http://wolfems.cart.net.au/cat/31938.html
Any input would be appreciated.
Edited by dirtyrs4
When my mate got his 100k service they had the cover off to replace plugs, seals, belts etc. The incompetent f*#ckers looked around the workshop this morning but couldn't find it and then put up the argument it wasn't there.
Makes me laugh, because from research and what people have told me it is a part which is needed for a series 1 because these are built in with the series 2. The bracket and whole black box isn't there. It looks like they bypassed the module and have joined two connectors across the cover. One of the modules support brackets and screw is still attached to the cover. It is evidence of it originally being there.
I reckon they were in a rush and forgot to put it back on and then lost it. The wiring loom setup looks different as well. The car always starts rough but then runs fine at idle and on the road. Would this cause any long term damage? Still the question remains-should he go and replace the igniter module or upgrade to a better direct ignition system? It seems a lot of people do this, especially close to the 100k service mark. RB coil packs seem to be trouble, causing loss of spark and misfire.
http://www.nengun.com/splitfire/super-dire...ignition-system
The reason I ask is I might look at doing this soon. Anyhow this is the wiring which seems to bypass the whole module-is this ok?
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
