Originally posted by Ryan D
R33 GTS4
2.5l, non turbo, all wheel drive, and sexy as hell.
cant go wrong
Yeah thats what i had heard the 2.5 in a 32 is lethal where as in the 33 its powerful but is held back by weight ratios.
But i dunno im just a kid, lol, keep the opionions coming
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585825
The fastest N/A's down the strip I know of are actually the R32 GTS25's, they come out factory with 142kw at the flywheel. With a bit of work they can run low 15's.
Even though the type S R33 tend to make a little bit more power(147), the extra weight of the R33 works against them.
But give me a R33 any day :P
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-585957
umm people are already buying them and putting them in storage in japan. when the car is 15 years old to the day u can bring it in, but make sure u research its not that simple, u need to apply for permission to import that vehicle and a whole range of other things.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586053
Let a company like prestige motorsport worry bout all that for you if you choose to import, i got the R32 gts25, its a nice car, my auto box holds it back but thats to change in the future. Got the 2.5ltr goodness and the lighter shell, more room in a r33, bigger backseat etc, more spacious, but the r32 just looks mean and ready to go.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-586065
The R33 GTS25 is quicker than the R32 GTS.
Last year at the drags a guy with a R32 2LGTS manual was running high 16,s for the 1/4 mile, that was with air filter,extractors and 2 1/4" exhaust. A R33 GTS25 will run high 16's stock.
https://www.sau.com.au/forums/topic/28142-32-or-33/#findComment-587424
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
