I have a set of brand new hsd coil overs tt model for a r33 skyline that i put in my car on friday so they have been in there 4 days and they are just to soft for me and i want to sell them to buy some hr's.
so they are $1399 brand new and i will be happy to let the go for for $1000
located on the northern beaches fo sydney,
prefer if you call me then pm as i dont always get time on the interweb to check.
James 0420-972-868
all tools and stickers included
TT TYPE COILOVERS
The new TT type coilovers from HSD have been designed with every-day driving comfort as a priority. They use a twin-tube damper design (hence ‘TT’) which is less aggressive than the large-diameter mono-tube type dampers in the HR series. Spring rates are also generally 20-30% softer than the race-oriented HR series. In most cases the top mounting plate features a rubber bushing to reduce noise and harshness, but for strut replacements a camber-adjustable pillow-ball top is used for a larger range of camber adjustment.
Like the HR series the new TT uses an adjustable base bracket for easy height adjustment. The dampers also feature a 12-step adjuster for damping force. For a low-key appearance the aluminium lock rings and top plates are anodised grey, with black springs and brackets. The spring rates listed are our standard specifications. Alternative springs are available to order.
Edited by kungpow
https://www.sau.com.au/forums/topic/281712-hsd-tt-coil-overs/
Hi mate
If your finding the TT's a bit softer than what you like, im sure you can buy stiff springs from Ottomoto for $100 a pair
( $100 rear $100 front ), well thats what i was told 2 weeks ago when i picked mine up.
Just an idea anyway
Cheers
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
