A'PEXi Turbo Model AX53B70 P25 (Basically an equivelant to a HKS GTRS) Have had the exhaust housing ceramic coated in black to keep temps down.
20,000kms old Purchased through Greenline 2 years ago. Still as good as new no shaft play ready to bolt on. Selling as I have changed to a GT35R, will also throw in a custom stainless dump pipe.
$1650
A'PEXi Super Suction Kit
Aluminium Hard pipe to replace the rubber intake hose between the AFM and the turbo, Hard to find.
$180
Also Have a set of 6 S15 injectors 470cc purchased from Deatschwerks also 20,000kms old Asking $380
All items located in Griffith NSW. Willing to post.
I made 250kw at 14psi, turbo is rated at 380ps, so capable of more. Trent as Status tuning told me he has seen these make close to 300kw on an SR20.
I have since discovered I have a large exhaust restriction which would have been limiting the potential of this turbo on my setup.
pm sent for injectors. will buy.
definantly consider the Super Suction kit sold if falls through. also interested in the turbo, straight bolt on? is there everything needed to bolt onto a rb25det? will take both off you if possible. thanks
Edited by john-e boi
hey mate.. i am interested in the injectors..
i want them for my r32 gtst..
will the fit straight into standard rail??
and will i need resister pack??
please pm me and let me know - am very keen
ben
if ur 32gtst is still an rb20, then no, they wont fit ur standard rail. s15 injectors are side feed like rb25's. rb20 and rb 26 are top feed.
ps. i'm keen on the injectors.. would u do cod? as i'm in brisbane.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
