Nissan R32 GTR Parts.
· Very Good Used Gear Box, Was Reconditioned previously was used only on a dyno car. Price $850.00
· Very Good Used Complete engine harness. Price $250.00
· Very Good Used Complete Chassis wiring from the head light to rear lights all fuse boxs etc. Price. $300.00
Located In Brisbane, Gear Box Delivery can be arranged at buyers expense.
Contact: Dalvin at 04168 13133 Or shoot me an email.
Edited by Dalvin
https://www.sau.com.au/forums/topic/282141-nissan-32gtr-parts/
What is the story re the gearbox? All shiny and new. Where bought from? Who reco'ed? What work done? How much work has it done? Push pull? When was the photo taken? Is this how it will be supplied now? How would you describe it drives?
20 questions I know, but some more details would be appreciated.
Feel free to PM.
Feel free to PM.
interested in the box too pending answers to the above.
Cheers
Johno
  • 3 weeks later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
