Hey All, I have a RB26 GTR sump fo sale - $250. Its still in fine working order as it came off for a recent 26/30 conversion and not
required anymore. Had no problems with this sump/diff and in excellent used condition/travelled about 72k. For those
interested send me a pm.
P&H will apply if not in Adelaide and will be at buyers expense!
Cheers HULI
https://www.sau.com.au/forums/topic/282460-rb26-gtr-sump/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
