  • Replies 49
Posted Images
Sorry to hear bout the car man.
I got pulled to the side of the road the other day by three highway patrols, checked through my whole car looking at everything, we joked around with each saying the three things in life that is gonna get you in trouble is "cars, money and women". He said he was impressed with the car as it was clean, said he was expecting it to be all dirty and "gunky" lol...I was missing a P plate, claimed I was going a bit over the limit, said I needed a engineers certificate for my exhaust and my geer knob was a defect. He said I passed his "attitude" test and he is gonna let me go, told me to have a good day and keep of the gas lol.
Lucky, every time ive been pulled up ive been nothing but friendly to em in the hope they let me off but its only happened once and the last one sent me to court for having a knife in my back pocket (comin home from work) which im pretty sure was because he was annoyed he didnt find any drugs (started talking about drugs first up, searched the car all over ect)
So the next time im pulled and just get attitude in return i rekon theyll lock me up when im done tellin em what i think of them ay :( and ive never been pulled over for anything serious, bit over the speed limit, slight traction loss ect :)
what made the gear knob a defect mate? mines stock but al worn out and ive heard they need to have the gears numbered on them.
Anyone who has the sticker problem, heres a quick diagram i put together for you.
Print it out then just use a bit of tape and you're brand new. :P
Haha that a awesome sticker broo :huh:
Don't think it will be to hard, also just to clear something up...Instead of putting the sticker on top of the gear stick, I can put the sticker just under the gear stick on the centre console correct?
Yes it will be fine near the gearstick. Cops tried to defect my JDM s15 gearkob as it had the S on it and not a H pattern. He went looking for others when i told him it was the stock knob and there is a H pattern etched into the plastic surround.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
