Gday fellow SAUers
i am currently looking at purchasing my first car, the car is an R33 GTR and is puting out about 300KW atw on a safe tune, the owner has a HKS twin plate clutch, i was wondering how this is to drive, he said it will take a while to get used to as its pretty much on/off but once you get the hang of it its pretty nice when shifting gears etc, i have heard great things about Jim berry and his clutches, and i was wondering if he could do anything to make the clutch feel more smoother or standard if i find it very difficult to drive,
any feedback would be appreciated,
cheers
Adam
https://www.sau.com.au/forums/topic/282598-hks-twin-plate-clutch-drivability/
All ive heard is that the HKS twins are painful. Like all after market clutches there are 'tricks' you have to learn to be able to drive them in traffice smoothly. It can be done too. But, if you try and drive the car like it has a normal clutch in it, you'll hate it and any passengers you have in the car will think you probably only hold an auto license.
Nismo would have been a better choice. Once you go nismo you dont even try anything else. They are that good.
Edited by GTRNUR
I had a HKS twin plate when I first bought the car as it came with it.
A bitch to drive with, there is not much play at all, it's either In or Out and if your not careful you can stall the car.
The make a bit of noise but that's not a problem.
They are great for high RPM launches and once your use to it, it's not a problem.
One of those Nismo clutch slave cylinders might help, or it might do nothing, just an option. Might be worth researching into it though.
I had a Nismo Clutch Slave Cylinder as well, but it need replacing earlier this year.
It's back to standard Nissan Clutch Slave Cylinder... To be honest, I can't feel much difference at all.
  • 5 weeks later...
i just got the nismo twin plate coppermixer n i got the nismo clutch slave.
only done few hundred k's on it so far but early thoughts are its a pain in the ass for normal driving. and also very girly light wieght on that pedal.
im hoping it will get easier in time but lets just say i wont be taking any dates in it for a while, less i wanna see that expensive dinner on the inside of my windshield.
i went from ceramic single plate that was heavy as hell prior to this and i loved that clutch till it started slipping. im under the impression it was just old as it come with the car and n held good for a couple of years. but with that clutch i could take off pretty well without even using the accelarator still be nice n smooth.
It comes down to how you try and drive them too. You cant drive a twin plate (nismo or other) like a normal clutch. They just wont becuase they grip so well.
If you try and slip the clutch a little when pullng away from the lights the clutch plates will grab and slip rapidly as the springs load up and release. This makes a terrible sound not to mention this eats up your plates quickly.
The way I drive with a twin plate in traffic is to bring the revs up a little more than you would if you were driving with a normal clutch, then let up the quickly but get off the accelerator so clutch engagement slows engine speed. With practice you can get the car rolling and have the engine speed around 1000 rpm with the clutch fully engaged then drive normally.
Granted you cant do this in bumper to bumper traffic and it tends to piss off tailgaters because you cant ride the ass of the car in front of you, but it does make your driving a lot smoother to the point that unless your passenger is watching what your doing they wont even pickup on it.
they are a bit difficult to get used to as everyone else has pointed out, but once you get the friction point sorted its no problem and very bitey on the uptake, and again has everyone else has said they make a bit of noise but are decent if you are making that kind of power
yeah im about ready to eat my words about the clutch now, done about 800ks with it more or less few days worth of driving and now i can take off a smoother. had to do 1 infront of a cop that put a lil pressure on me not to spin the wheels :bunny:
trying to learn while getting sh*tted off with it prob didnt help :)
now im having trouble driving my daily after as ill be slowly letting the clutch out waiting for the sudden bite.
im guessing in a couple of months it will become 2nd nature more or less.
Edited by Inline 6
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
