Has anyone replaced/used bigger/better speaker cables instead of the standard factory ones in their R34 GTT?
I'm going to use a 4-channel amp from the boot and run the cables from there using the passenger side to the front speakers. (The power cable from the battery and the remote cable will be run through the drivers side.)
The factory wiring is usually not the best quality, so I'd like to replace them with better ones.
Can they be run through the factory connector in the door? Is there enough room in the connectors to run extra wires?
Or do I have to make an extra hole in the door to run the new cables trough?
Edited by mgb2002
https://www.sau.com.au/forums/topic/282796-speaker-cables/
sounds a bit wonky in your words..lol but yes I have run larger wires into my GTT doors, it is a bugger to do !!! very tight access
if your not after massive loud tunes you can run the amp speaker wires to the factory harness behind the radio, and solder on from those to avoid the wire running into the doors ?(most common dealers would do this route unless requested to run new wires into doors)
amp wires will go down drivers side to battery, RCA/trigger wire down passenger side, speaker wires down the middle or passenger away from RCA
fused at the battery, grounded in the boot to a solid bolt with paint removed around it, dont drill into fuel tank,Hicas steering lines, etc ?
if your not sure take it to a shop to get it done properly. and remember the airbag and seat belt tensioner pre-charges can be triggered if you dont use caution !!!
https://www.sau.com.au/forums/topic/282796-speaker-cables/#findComment-4763388
Yeah i ran my cables through the molex plugs in my R33 and it was a massive job!! to have a shop do this they would change you close to $500. In my car i have 2 runs of speaker cable on both sides and an optical from the head unit to the boot.
As mentioned by sapphiregraphics the best option is to run new cable to the door then use the existing cable from there.
https://www.sau.com.au/forums/topic/282796-speaker-cables/#findComment-4764870
Hey mate,
Keep in mind that the shorter the cable length, the smaller the wire. Don't go giving yourself headaches running 12g wire 2m when a 16g will work just fine for the amount of power. That said, it never hurts to go bigger.
That's a good point. But given that the only real place you have in a skyline to mount an amp is the boot, by the time it gets from the amp through the door and on to the speaker it is close to 6m. It also depends on the amount of power you're running as the loss in the cables is proportional to the current squared. I'm running close to 200wrms a side so i felt 12g was required, plus i like fat cable :(
https://www.sau.com.au/forums/topic/282796-speaker-cables/#findComment-4769797
That's a good point. But given that the only real place you have in a skyline to mount an amp is the boot, by the time it gets from the amp through the door and on to the speaker it is close to 6m. It also depends on the amount of power you're running as the loss in the cables is proportional to the current squared. I'm running close to 200wrms a side so i felt 12g was required, plus i like fat cable :)
12ga is overkill for front speakers on that short cable run ???? on 1 pair of speakers ? at 200watts your only pulling around 17 amps (off the top of my head math..lol)and the load capacity of the wire is 41 amps for 12ga, 32amps for 14ga ? so you wont be stressing it too much and the Resistance is also minimal on that short run
its much more important to run it properly to avoid shorts,kinks,induced noise from computers, and other power lines. and solder and tape the connections even it your using crimp on connections, they do fail.
buy wire that is made for car audio speakers, hardware store lamp cord works and is cheap but its not very flexible and can be brittle inside and out due to the UV and heat inside cars
and mount the speakers flat, not warped . protect from water on the top of the speakers from the windows
think we have filled this thread enough now..lol
https://www.sau.com.au/forums/topic/282796-speaker-cables/#findComment-4770131
True, but having said that the load limit of a cable is how much current it will take before it start to get too hot, once your getting up to there power loss is the least of your worries :D I agree 12g is large but given the amount i spent on my amps and speakers i wanted to transfer every watt i could, plus it's just as easy to run 12g as it is to run 16g and the cost difference is marginal.
https://www.sau.com.au/forums/topic/282796-speaker-cables/#findComment-4771120
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
