Trust T88-34D Turbo for sale
Item is used but in very good condition
Has basically no shaft play
No longer needed as i have changed my plans
$1500
Located in Adelaide
pm or txt me on : 0402850468
Willing to post at buyers expense
Pics will be up tonight
https://www.sau.com.au/forums/topic/282881-trust-t88-34d-turbo-for-sale/
  • 4 weeks later...
still here needs to go
what rev range would the boost come on bolted to the side of an rb26?? what mods would i need to do to a basic standard engine to run it?
id say boost would come on around the 4800-5200 range
when on boost it will pull like a mofo tho.
not sure what other mods u would need apart from a manifold to suit and an aftermarket ecu to be able to tune it properly.
yeah got pfc. 044 pump, will have 700cc inj
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
