Well oil seal it self won't fail. Its just a stainless steel circlip. Its the bearings that fails, Then it lose control of oil flow and cause 0il to hydraulically leak through the seals.
To check the condition of turbo, simply move shaft up and down then left and right for shaft play. Should not have any thing above 20thou.
https://www.sau.com.au/forums/topic/283380-turbo-oil-seals/#findComment-4768583
Is this a proper build turbo or a ebay special?
assume is a proper build turbo. The other reason for it to leak would be oil drain related. The turbo runs off a gravity drain system, So when you do see smoke it means the drainage cell on turbine end of bearing housing has been filled. unless bearings are worn which allow movements to the shaft its very rare for the seal it self to fail.
For ebay specials. It could be vibration from bearing and shaft tolerance, broken seals from bad materials, faulty bearing housing, bad oil division and so on.
This is what a oil seal looks like:
https://www.sau.com.au/forums/topic/283380-turbo-oil-seals/#findComment-4769942
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
